08-23-2016, 08:54 PM | #1 |
Wiper switch
So my original wiper switch finally fell apart so had to order a new one from Ecklers. I installed it and it is extremely slow. Slower than normal and only has 1 speed instead of 2. I didnt change anything else besides the switch. Could it be a faulty switch or would it be something else? Like I said nothing else was changed besides replacing the switch.
08-23-2016, 09:29 PM | #2 |
Re: Wiper switch
if it has only one speed the its a 1960-63 switch, you should have gotten a 2 speed switch 67 or 68-72 switch
08-23-2016, 09:41 PM | #3 | |
The Older Generation
Re: Wiper switch
LockDoc
08-23-2016, 09:44 PM | #4 | |
Re: Wiper switch
Wouldn't the single speed switch only have 2 terminals instead of three? LockDoc
08-23-2016, 09:56 PM | #5 |
Re: Wiper switch
It is a 3 connection switch. Wouldn't the ground be the switch to the dash?
08-23-2016, 11:19 PM | #6 |
Re: Wiper switch
Lockdoc is correct the 60-63 switch would have only 2 terminals , if you have 3 terminals then you have the 2 speed switch, but there is like I said a 67 is one year only 2 speed switch and a 68-72 2 speed switch I see listed in parts books . I would check in to that and see if that has anything to due with your issue . then move on from there I am sure there is a test proceedure for the wiper motor /switch
I am not sure but I thionk the switch has not 12v running to it the motor gets the 12v and as you select your functions you are completing ground circuts to the motor for slow/fast and washer pump operation |
08-24-2016, 01:35 AM | #7 | ||
Re: Wiper switch
http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
