![]() Join Date: Jul 2016
Jimmy Engine
Well finally got the new engine replaced. Along with the trans and transfer case rebuild. Here some pics. Does anyone know what color paint pen they used at the factory to write the body color code on the firewall with. I copied all the orignal paint marking I found and would like to put them back on. Maybe next year do the frame and stuff. Want to drive it alittle bit before the snow flys.
Re: Jimmy Engine
is that what a clean transfer case looks like?
'72 K5, known as 'the Fox.' |
Re: Jimmy Engine
a couple before pics
Re: Jimmy Engine
Took forever to clean that thing .... lol
Re: Jimmy Engine
CLEAN BUILD!! I love that transfer case. Makes me want to pull mine and paint it.
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=706924 |
![]() Join Date: Nov 2013
Re: Jimmy Engine
The marks on mine are white..........but they may have been different on lighter color paint...?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Re: Jimmy Engine
Pretty sure my 205 was red oxide primer when new.
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Jimmy Engine
Looks great! Here's one thread that shows some example firewall marks: http://67-72chevytrucks.com/vboard/s...d.php?t=144648
Curious if you plan to use the heat stove that was around the LH exhaust manifold. If not, I'd buy it for use on my blazer build. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Jimmy Engine
I believe those markings were made with grease pencils, not paint pens.
Re: Jimmy Engine
Looks Awesome!! I'm just about ready to drop my motor in as well. Hope it looks as god as yours does.
Re: Jimmy Engine
Yeah I will try to find it for you... Seems to have disappeared.
![]() Join Date: Mar 2004
Re: Jimmy Engine
All looks great. Did you rebuild the t-case yourself?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Re: Jimmy Engine
No I didn't a Buddy of mine owns a Transmission shop and He did it. If you have questions I can get you his info
I'm trying....
![]() Join Date: Oct 2013
Re: Jimmy Engine
Very clean work. Nice job. Obviously the firewall markings were done at the factory on a wide open firewall before any installation. Trust me when I tell you, it will be difficult to put the markings on there with the engine and firewall mounted components in place. Some of our markings got smudged late in re-assembly and I elected to "erase and replace" the affected markings...and it was a challenge. The best way is on a blank tub...just like they did it originally.
...more pics please. Quality build.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#15 |
![]() Join Date: Jul 2010
Re: Jimmy Engine
Here is my firewall marks. They are hard to see and may not even help you but since our color is the same, thought it might be a start.
#16 |
Re: Jimmy Engine
Here is one more.
#17 | |
GMCDAC
Re: Jimmy Engine
Your build and detail looks great! I can't remember what year your Jimmy is, but here's a couple pics. Don't know if it will help. I'm about ready for install but still need to paint the air cleaner.
Wish I would have known that a few months ago when I built mine! It's going to stay orange now! Quote:
I took quite a few pics building mine last spring if you need any. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
#18 |
![]() Join Date: Apr 2012
Re: Jimmy Engine
My 71 has a couple of different colors of grease pencil. I will attach a few pictures. Firewall, a/c compressor, front frame horn, and gas tank.
#19 |
Re: Jimmy Engine
More
#20 |
Re: Jimmy Engine
Another
#21 |
Re: Jimmy Engine
Gas tank
#22 |
I'm trying....
Re: Jimmy Engine
Which plant?
#23 |
Re: Jimmy Engine
#24 |
Re: Jimmy Engine
so what does this mean,,719 BK |
