Old 08-28-2016, 11:01 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
5x5 to 5x4.75 conversion
I have searched and everything is for the Lighter Duty 1" rotors. I have the HD 1.25" rotors on my 73 and I want to change the bolt pattern to 5x4.75" bc the I have a wider selection of wheels with the 5x4.75" bolt pattern. I will be running a 15x6/15x12 wheel combo and if I can change it to 4.75 bolt pattern then I can have 4 wheels and tires for the price of just the rear wheels in tires in a 5" bolt pattern.
All of my front suspension stuff is new so i would like to do this without replacing too many parts.
Please help
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 08-28-2016, 11:07 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 5x5 to 5x4.75 conversion
what wheels are you looking at? going to smaller rotors to get a better wheel price doesn't make sense.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-28-2016, 08:27 PM   #3
bigblock73
yeller
bigblock73's Avatar
He didn't say smaller rotors..just a smaller/car bolt pattern for better wheel selection.
bigblock73 is offline   Reply With Quote
Old 08-28-2016, 08:30 PM   #4
bigblock73
yeller
bigblock73's Avatar
You could have your rotors and axles redrilled for the 4.75 bolt pattern, or run spacers. Personally...id keep the 5 on 5 and spend the money...
Old 08-29-2016, 10:03 AM   #5
dragonball98312
dragonball98312's Avatar
I tried doing the opposite and going to 5.5 to run truck rallies on my s10 and I tried 3 machine shops all refusing to redrill rotors. Too much of a liability to them
dragonball98312 is offline   Reply With Quote
Old 08-29-2016, 11:05 AM   #6
andrewmp6
The front will take new hubs and rotors the rear will take redrilling the axles or custom axles made and new drums.Honestly for the time of money that will cost the 5x5 rims might be cheaper then swapping lug patterns and buying rims.Have you looked around summit racing or jegs for the rims you want?Both have a lot of them in 5x5 and the size you want.
Old 08-29-2016, 02:57 PM   #7
softballnrd27
I'm not concerned about the rear bc I am building a 9" for it. I was concerned about the front and just like I figured, I will have to change out parts which I'm not going to do. It looks like I'll have to stick with the 5x5. The cost to send out my extra set of rallies to get them widened to 15x12 to try and save some money doesn't add up in the end. $195 per wheel to perform the service plus shipping to and from. It does save me from not having to buy front wheels but I will have at least $500-$600 wrapped up in the 2 wheels when it's all said and done. Thanks for all the advice and talking some sense into me.
There are plenty of wheels that I want in a 15x12 with a 5"BS but they are just a little pricier.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 08-29-2016, 10:28 PM   #8
Warrens69GMC
Early wheel company says they have 15x12 for 140.00 each (bare)
http://www.earlywheel.com/rallywheels.html
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-30-2016, 02:54 PM   #9
MikeB
MikeB's Avatar
I thought all 73-up truck rotors are 5 x 5, even the light duty models in the 80s with 1" wide rotors. Other than re-drilling yours, you'd have to adapt passenger car rotors and maybe even spindles, and you'd end up with a very light duty setup.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-30-2016, 06:46 PM   #10
SCOTI
SCOTI's Avatar
Correct.
5x5" for 1/2 ton trucks. Different rotors for Lt duty (1.00"w) & HD (1.25"w) which have different bearing set's. The Lt duty rotors bearing set is common w/the F-body 1Le brakes which gives the car pattern but requires the Lt duty spindle & caliper set-up which is technically downgrading vs the thicker rotor.
To keep HD 1.25" thick rotors & get a car pattern, one would have to re-drill the pattern, use adapters, or wait for some aftermarket company to make some.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
