EGR Delete & Custom chips - Info/Links
This thread is NOT FOR ARGUING about what EGR does, or if it sucks, or whether deleting it has any benefits.
This thread is only here to save people time, aggravation and money by providing links to QUALITY parts & services. Most of the pollution crap has been off my truck for years. I finally deleted the EGR valve and EGR solenoid. Because my Blazer is TBI - I had a hard time finding a Block Off Plate that lined up with the bolt holes in the GM TBI manifold (Ya, the carb'd EGR block off plates are cheap and easy to find... but they DON'T work for TBI.) ...and I needed someone who knew wtf when programming chips. This guy Jim is a one man machine shop and does outstanding quality work: http://www.custombilletworks.com/products.php (541) 760-7292 and he returns calls. This guy programs chips for performance & towing. He'll delete the EGR off your chip so your truck isn't throwing codes at you, or program you a custom chip for your truck. http://www.tbichips.com/truckmods.htm He also has a store on ebay. Click here.
"Go Hard - or Go Home!"
Resident of Here
Re: EGR Delete & Custom chips - Info/Links
Thanks for the info!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
He has the 1980's 454 EGR Block-offs also and the L98 kit looks interesting too. I wish I knew about that when I had the El Camino and the other K5 set up with EFI
1970 Chevelle SS396 1984 K5 Blazer -First Truck! 1999 Big Block K2500 'Burb |
Resident of Here
He will be doing my custom chip. I'm going to 383 my 88 burb with a vortec engine.
#5 | |
PITbut
On my 2008 Dodge mega 6.7 diesel, i deleted the dpf/cat/ egr/ egr cooler, oxygen sensors, and installed a smarty jr tuner. On the medium power tune i still get 5mpg more accross the board. Highway or city or towing.. My towing went from 10mpg average to 14mpg.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
do i have to get a chip if i delete my egr?
if you dont it will trip a code at cruising speeds. I bought an highrise dual plane carbed intake for mine without the egr port, and my vortec heads require way to much work anyways. But i left the egr solenoid hooked up and just capped the vac line. When i had the VSS still it would trip a code around 45mph, so i solved that by installing a np205 and not hooking up a VSS.
Hey I live in nd no emissions here I need help bypassing vacume lines on a 1985 305 chevy c10 I bleep my last motor because I was taking short cuts
| Bookmarks |
| Tags |
| 1987, blazer, chips, egr, tbi |
