Closed Thread
Old 08-28-2016, 05:52 AM   #4201
66clow
66clow's Avatar
Re: What did you do to your truck today? Chapter II
More body work. Welded up the old farm mirror holes. Grateful to have access to some body shops to work in. Perks with the job. The other day played around with a sharpe, not sure if I will continue with it.
66clow is offline
Old 08-28-2016, 06:00 PM   #4202
Possmguts
Possmguts's Avatar
not much.. just stuck this where it goes.. that Captain Fab mounting bracket is top notch...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 08-28-2016, 06:05 PM   #4203
ohboy321
ohboy321's Avatar
Installed 4 newer/better Yankee 77 marker lights, replaced 2 lenses that were white with amber ones, and generally made them all look better.
ohboy321 is offline
Old 08-28-2016, 06:20 PM   #4204
Jarvis-69 GMC 1500CK
Is it normal for the rear light lens to be really tough to get in?
Seems as if it has shifted out of alignment, cant get the bottom screw back in.
Jarvis-69 GMC 1500CK is offline
Old 08-28-2016, 06:24 PM   #4205
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Does your truck have the chrome trim around the taillights? If so yes, you have to finess them to get them in. Where do you live in Saskatchewan?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 08-28-2016, 08:09 PM   #4206
custom10nut
custom10nut's Avatar
Changed transmission filter, and rear diff fluid today(no leaks) and changing the ball joints and tie rod ends tomorrow. One stop at the alignment shop, and I'm off to the races...
custom10nut is online now
Old 08-28-2016, 08:10 PM   #4207
66clow
66clow's Avatar
Installed my flywheel cover. And discovered about a pound of dirt inside the drivers door? Anyone know why that would be there primered the door and fender a little better from my body work yesterday. Closer to being one color at least.
66clow is offline
Old 08-28-2016, 08:22 PM   #4208
In The Ten Ring
Cleaned up the hardware (bolts and that angled steel bracket) to the driver side inner fender and outer fender. I just used Evaporust and wire wheel on that bracket and I have to say, it doesn't hold a candle to the effectiveness of electrolysis and Evaporust.
In The Ten Ring is offline
Old 08-28-2016, 08:32 PM   #4209
gable74
gable74's Avatar
got a few things done today on old blue.
Got the new bumper put on...
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline
Old 08-28-2016, 08:35 PM   #4210
gable74
gable74's Avatar
Got the blue bench installed...
gable74 is offline
Old 08-28-2016, 08:37 PM   #4211
gable74
gable74's Avatar
Got one stainless mirror installed, will do the other next weekend.
gable74 is offline
Old 08-28-2016, 09:07 PM   #4212
custom10nut
Old 08-29-2016, 12:36 AM   #4213
Pierceland, it is on highway 55 going to Cold lake AB, im like 10 mins from the AB/SK border. My truck actually comes from Buffalo narrows, which is even further north from
Old 08-29-2016, 06:27 AM   #4214
berch 69GMC
berch 69GMC's Avatar
Blacked out the grill
berch 69GMC is offline
Old 08-29-2016, 07:35 AM   #4215
cruisinthe34
cruisinthe34's Avatar
Got the Drop Spindles and Springs installed:
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline
Old 08-29-2016, 10:17 AM   #4216
Ekliptix
Ekliptix's Avatar
Originally Posted by JJ's Sierra Grande View Post
Is that place in the SE? I used to use a place over there years ago, wasn't sure if it was still there. real convenient and yes cheap.
9516 - 40 St SE, Calgary, AB T2C 2P3
http://www.consolidatedcompressor.com/diy.html
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 08-29-2016, 12:40 PM   #4217
1968aj
I thought I would try to get the last bit of shine out of my old 69. I tried clr but that must be just good for rust. the best way I found was to wet sand it with 1200. then I used meguires mirror glaze to get scratches out. finished it off with the mothers. it was a lot of work but it looks a little better. pictures show some before during and after.
1968aj is offline
Old 08-29-2016, 02:58 PM   #4218
BugzC10
BugzC10's Avatar
Finally adjusted drivers side door, install new door seals (2nd Gen) SS thresholds and inside rear view mirror all from GMC Pauls. If I could figure out how to load more than one picture....on an iPad
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 08-29-2016, 11:06 PM   #4219
Steeveedee
Who Changed This?
Steeveedee's Avatar
Got the appropriate adapter to get the rear brakes working on my truck. I still have to run new front lines to the new flex lines on the rotors, after converting to front disc brakes. Almost done. I put in new upper and lower control arm shafts and ball joints (the ball joints came with the kit). The ball joints were ORIGINAL from 1970, as were the rest of the steering components! I will admit that getting the master and booster replaced was a bit of fun that I am looking forward to never doing again. I'm going to make new lines for the front brakes with parts from the parts store. A bit different, drum to disc. I was thinking rear disc somewhere down the road. Not so sure, any more. Next is getting the wiring for the new (to us) trailer we bought installed. I have an old 5-pin connector. Talk about old-school! Got to get a 7-pin connector setup.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 08-29-2016, 11:25 PM   #4220
TwoFiftyShifter
I pulled the 71 Camaro wheel I recently installed. The wheel is small and turn signal stalk was too close, my knuckles kept catching it. I modified it and its perfect now.
Repainted a pair of 15x8 rally wheels argent silver
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline
Old 08-29-2016, 11:30 PM   #4221
custom10nut
I attempted to change out my ball joints today. I accomplished three, but ran out of time tonight. I'll do the last one and the tie rod ends on Saturday.
The YouTube videos I watched sure made it look easy, but then again they weren't replace OE ball joints, on a 46 year old truck either. Knowing now what I learned today, Saturday should go smoother, and a lot less frustrating.
Old 08-29-2016, 11:50 PM   #4222
Metaldoc
Metaldoc's Avatar
Made up some screens from rain gutter screen.
Metaldoc is offline
Old 08-30-2016, 12:39 AM   #4223
wpavlis
Drove it around the block while sitting on a bucket because, you know, I couldn't let cobwebs grow on it.
wpavlis is offline
Old 08-30-2016, 01:16 AM   #4224
1968aj
Finally got my wheels on . They were sitting in garage for about a year.
1968aj is offline
Old 08-30-2016, 04:55 PM   #4225
In The Ten Ring
Love the stepside man and you have the spare where God told GM He intended it to be.
I paid for two fender emblems, put up a counteroffer on two more, filtered all of the Evaporust I used last week, and I am just about to finish up spraying the bolts and clips from the removed inner fender with NAPA Rust Treatment.
Closed Thread
