#76 |
![]() Join Date: Apr 2003
Re: Parts from a 69 cst
Sorry , no help on the engine stand or harness piece.
#77 |
One of the First
![]() Join Date: Jan 2000
Is the seat still available? I can pick it up. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#78 |
Is the cluster still available? How much shipped to 93267
Also is the intermediate steering shaft available and how much? Thanks |
#79 |
do you have an antennae? I only have am, but would be adding am/fm at some point and my antennae is toast. Doesnt need to be show quality, but in one piece would be nice. thanks
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350 06 Yukon XL Denali - Stock |
#80 |
Active Member
![]() Join Date: Nov 2002
Do you have a distributor hold down clamp?
Thanks Don Brace
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
#81 |
![]() Join Date: Mar 2012
5 blade clutch fan $50. is it 18''?
#82 |
Caddyfront - the cluster is good for parts . the gauges are faded and it has an extra hole in the bezel from the manual throttle. $65 plus shipping for it and the intermediate shaft
Greywurm - sorry no help Don brace- $10 shipped if I have an extra. I will check tomorrow. gmc 2500 4X4- I will check the fan size tomorrow. |
#83 |
Do you still have the steering column? If so, how much for the complete unit? Also power steering gear box available? Thanks.
#84 |
Hey, do you still have the fan shroud?
If so, does it have any cracks? Are the bolt points intact? Will it fit any radiator core support from 1969 to 1972? If it will fit my 1972 I'd like to have it. |
#85 |
Coop3726- the column has been taken apart , cleaned and bearings greased. One of the tabs that holds the pointer is broke off and let's it move to the side a little. You can see this in one of the column pics. I all ready have a gearbox off. $125 on the column $75 on the gearbox. I'll be at the. N E Ga swap meet on the 3rd if your interested.
In the ten ring - the shroud is in good condition with no cracks. It should work in all 67-72 trucks with a small block V8. |
#86 |
I may see you there. Thanks.
#87 |
Dan brace I do have another distributor mount. GMC 2500 4 X 4 the fan is 18 inch diameter
#88 |
i 4got i asked you, im sorry i just bought 1
#89 |
Southern parts, do you have the passenger side floorboard vent? I need one.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#90 |
do you need an a/c or non a/c vent?
#91 |
May have said it wrong. The kick panel vent door.
#92 |
I understood what you are looking for . the a/c passenger vent is different than the non a/c vent.
#93 |
Non AC.
#94 | |
#95 |
I'll take it
#96 |
#97 |
Is the side trim good on the bed? if so how much for the side chrome off the bed of the truck?
#98 |
Sorry I meant I'll take the cluster and intermediate shaft
#99 |
ripdog28 - $15 plus shipping. It will be this weekend before I can get a quote on shipping.
In the ten ring- I've never seen a v8 shroud in a 6 cyl trk. Toy Soldier - sorry, no. bed trim. |
#100 |
Do you have other Seat Belt Retractors L & R, don't need to be in working order.
