08-21-2016, 05:29 PM | #26 |
Re: MIG Welder decision
I would get some gas lines for welding and get rid of that clear tubing. Something like this depending on what threads you need. http://www.usaweld.com/Gas-Hose-p/hose.htm
08-21-2016, 06:50 PM | #27 |
nice welder you got there...wish they had that inverter 211 when I bought mine. On your welds...the spots there in the middle right look real nice. The others look cold or maybe your gun was too far away from the metal. I have found that I use the autoset and it does work right, used it both manual and autoset and autoset was the best. When I bought it I thought the autoset was dumb because I have been mig welding for over 25 years but it does work!
08-21-2016, 10:22 PM | #28 |
meowMEOWmeowMEOW
Cougar, here's my .02 on the weld I see:
It looks like your trying to go for the overlapped "bead" aka the Mig-like-tig weld. Totally fine to do, but on thin sheetmetal (like a truck repair) it doesn't really teach normal welding technique. As you overlap those little beads, your keeping a lot of heat in one area creating a higher chance of warpage. Try spacing your tac's out an inch or so and keep your fitment tight. On a sheet repair you'd hammer and grind the seam, and then come back for another round of tac's and small welds, planish, repeat. To improve your general welding, get yourself some thicker material to practice on. Thicker stuff can be a bit more forgiving on heat, and you can get a better (longer) time with the puddle to observe its patterns. As I mentioned above, the technique on the thin stuff is pretty different than "structural" welding for lack of a better term. Pickup some scrap 1/16, 1/8, 1/4 flat and/or some sch40 and 80 black pipes. With that stuff, watching videos from Jody @ WeldingTipsAndTricks, and setting up your scrap in the basic 1g,2g etc etc positions, you can progress through most of the basic fitments and weldments, and it'll give you a really solid base for any fab you want to attempt in the future.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-22-2016, 03:44 PM | #29 |
Right now I just want to get to the point where I'm comfortable welding in the patch panels on my Suburban. Continuous welding on heavier metal is something where I can lay down a respectable bead.
On this piece I cut it apart and welded it back together. Welds 1,2 & 3 are butt welds using Harbor Freight butt welding clamps. Welds 4 & 5 are lapped. I used a flanging tool to create the lap. On all of the welds they were tacked at 4 points. I used single bursts to add to each of the tacks never doing more than two bursts in a row. If the metal felt hot I took a break for a few minutes. By weld 5 I thought I was starting to get the hang of it. On the two lapped welds I increased the heat setting a little bit from auto set. Oh and my gas pressure is set at 18. Thanks for the tips and comments. Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
08-22-2016, 03:47 PM | #30 | |
Thanks Paul
08-22-2016, 05:36 PM | #31 |
id weld /blow air on weld /hammer and dolly spot if needed /grind with thin wheel 90 degree to weld /and or use a shrinking wheel if needed?? good luck
08-22-2016, 05:46 PM | #32 |
i woudlnt worry about the clear tubing /a lot of new welders come w/ that ???
08-22-2016, 11:15 PM | #33 |
08-23-2016, 12:18 AM | #34 |
The tube is fine. I dont like the clamps or flanging. The clamps are two wide of a gap for me and the flanging prevents you from being able to planish, makes bodywork harder, and leaves a place for moisture to accumulate.
I will use the clamps if my gap is bad and allows for it but I prefer a gap that is no wider than the wire thickness I am using. Here is what I shoot for. I tig most of my sheet metal work now but keep the fit up the same. When using mig I will set the welder to somewhere between 1/8'' and 3/16''. I never do two tacks next to each other. This is done with mig. This was three rounds of tacks letting it cool in between. I would normally planish in between each set of tacks but I didnt have anyone to hold the dolly with this section. Now for fit up I use clecos. They are really cheap and easier to work with.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-23-2016, 09:28 AM | #35 |
Great pictures. Thanks for all the tips. With the clecos you weld up the holes afterwards?
Paul
08-23-2016, 11:11 AM | #36 |
Yeah. For that I use a mig. It leaves an 1/8" hole. Just a quick pull of the trigger and you are done.
08-26-2016, 08:53 PM | #37 |
I would say they're still on the cold side as evident by the cold lap where one tack meets the next, crank it up to nuclear. Or not but just a little lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
08-27-2016, 09:56 AM | #38 |
I just bought the Miller 215. Tried it out last night for the first time. With the autoset, it piles a huge bead compared to the lincoln that I have been borrowing for the last few years. I hate grinding! I turned off the autoset, ran about 17-18 volts and 190 wire speed. Had great penetration on tight gaps, and not too much bead to grind. Don't take these settings for gospel, I'm still trying to dial it in to my technique. Using .023 er70s-2 wire.
Also, lap welds are not for "visible" sheet metal. Do a butt weld on the panels that are visible. |
08-29-2016, 01:04 PM | #39 | ||
"I ain't nobody, dork."
That Miller 211 is a nice unit.
I have a Lincoln Power Mig 140C and it suits me perfect for the body work I've been doing on my 1972 GMC. I can fine tune my heat and speed settings without preset "clicks" on the knobs. That's the main reason I bought it. This is the first time I've done sheetmetal repair work as well. With my MIG I try to keep a gap far enough between panels for the weld to penetrate both panels, so when I grind away some of the weld, there will be strength in the weld. But I'm still learning as I go. So my welds are looking better since I started. Gary
08-29-2016, 05:55 PM | #40 |
Hollister Road Co.
try between 20 and 25 on your gas.
Here is the best way to dial in your machine for a particular gauge sheet metal quickly. https://www.youtube.com/watch?list=P...&v=6eB9qnktmDI |
