Old 08-31-2016, 08:10 PM   #51
boynton
boynton's Avatar
Re: 69 swb turbo Ls swap
moving right along. I used db rods and minis in Taylor tx for my tank. very nice quality and he can build the top of your tank to fit any pump or sender. I used the stock fuel pump out of the donor truck (I know this won't work for you since you need more fuel).
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-31-2016, 10:25 PM   #52
69restomod
Thanks sounds great I'll have to check them out! I got the donor truck out of my driveway this evening, so I have more room to work now. I talked to my buddy pat who does my transmissions and they got the trans torn down and everything looks good nothing bad so they are gonna put a shift kit in it and some bushings and it will be good to go!
Talked to autometer today since I already have all autometer sport comp gauges they said if I get the electrical version of my speedo it will be a direct hookup to the sender in my 4l80e so that's good news!
Called 5-6 different lsx harness conpanies the only one I could get ahold of was modern vintage and talked to them for awhile and they had a lot of good things to say and were very helpful so they are on the top of my list now,hopefully will hear back from some other companies because I like to have options!
Turbo and wastegate should be here tomorrow will post pics when I get the package!! 🤑🤑🤑🤘🤘🤘
69restomod is offline   Reply With Quote
Old 09-01-2016, 02:00 AM   #53
mongocanfly
mongocanfly's Avatar
I had good luck with psi harness..I had one little issue (blade connector to fuel pump came loose) but they were quick to respond..
Old 09-01-2016, 10:19 PM   #54
69restomod
My turbo and wastegate came in today it feels like Christmas!! 🤑🤑
Old 09-01-2016, 10:25 PM   #55
69restomod
The turbo smart power gate 60 is huge!! This is a very high quality piece! I cannot wait to start fabbing this stuff up!
Old 09-01-2016, 10:26 PM   #56
kvn1011
Kvn1011
kvn1011's Avatar
kvn1011 is offline   Reply With Quote
Old 09-01-2016, 10:26 PM   #57
kvn1011
Kvn1011
kvn1011's Avatar
nice!!
Old 09-01-2016, 10:40 PM   #58
69restomod
Thanks!!
Old 09-06-2016, 10:20 PM   #59
69restomod
Got my blow off valve ordered and on the way a tial q 50 mm black bov!
Old 11-13-2016, 11:58 PM   #60
69restomod
Been awhile since I've posted but have been super busy with side work and have been collecting parts! Got a tick performance stage 2 ls2 turbo cam with valvesprings and titanium locks and retainers, also got a circle d triple disc billet converter, and also got the passenger side up and forward header all fit up, I will post some pics of the progress!
Old 11-14-2016, 12:00 AM   #61
69restomod
Circle d triple disc billet converter
Old 01-22-2017, 03:08 PM   #62
69restomod
Motor and trans are in ended up using the ict billet accessory setup with 98-02 ls1 power steering pump.
Old 01-22-2017, 03:13 PM   #63
69restomod
Another shot from the front of the truck !
Old 01-22-2017, 04:46 PM   #64
boynton
boynton's Avatar
Looking fantastic
1970 SWB Step-Side
Old 01-22-2017, 04:57 PM   #65
69restomod
Thankyou!
Old 01-31-2017, 06:33 PM   #66
69restomod
Got the primary tubes welded on the headers and the crossover all fit up!
Old 01-31-2017, 06:36 PM   #67
69restomod
Another pic from upfront! Need to get some 4 inch tubing for the downpipe and figure out my wastegate placement and order my ls swap radiator so I can make my hardlines for the coolant lines around the crossover, but I have a bunch of orders for turbo kits and catch cans so it might be a week or so before I get back on it.
Old 01-31-2017, 06:44 PM   #68
69restomod
Here's a picture of the passenger side header with the primaries welded and spike welded before I put the collectors on!
Old 02-01-2017, 03:40 AM   #69
boynton
boynton's Avatar
Nice work. Is there more room between the front of the motor than it looks? If not are you moving your radiator to the front side of the core support to fit your fans? It's hard to tell. Looks like all business under there!
1970 SWB Step-Side
Old 02-01-2017, 10:23 AM   #70
69restomod
Thanks! Yea from that angle it doesn't show how much room there is with the fans installed there is about an 1-1/2 between fans and the the tubing I kept the crossover closer to the motor then the fans, I still need to get my ls swap radiator and might switch to a low profile fan setup but I plan on running the radiator in the factory position.
Old 02-01-2017, 10:59 AM   #71
boynton
boynton's Avatar
Man that looks tight! Will it cause any heat issues being that close?
1970 SWB Step-Side
Old 02-01-2017, 11:14 AM   #72
69restomod
pictures make it look tighter than what it is, I plan on having everything ceramic coated so I'm not worried about it,
Old 02-01-2017, 11:21 AM   #73
boynton
boynton's Avatar
Should look super nice. I can wait to see it!
1970 SWB Step-Side
Old 02-01-2017, 12:25 PM   #74
69restomod
Thanks man! Once I get the new radiator in there I'm gonna decide if I want to move the radiator forward a little it looks like with a little bit of work I could move the radiator forward about 1-1/2 which I would be happy with! And if I get a low profile fan setup I could gain another 1-1/2 or so, so we will see!
Old 02-01-2017, 03:07 PM   #75
Kainedogg
Kainedogg's Avatar
Love this build. Keep up the good work as your schedule permits brother.
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
