08-30-2016, 02:47 PM | #1 |
Front Cab Support Frame Mount
Hey all,
On the cab support that is riveted to the frame, how large a hole should it have on top for the bolt to go through? I took my cab off along with the old crushed rubber bushings and found that one side has a 2.5" diameter hole and the other side has a 1.75" diameter hole. My guess is this was caused by years of rusting and rot. I think they should only be about .75" in diameter or maybe .5" to allow the bolt to go through and for small alignment adjustments. Comments? |
08-31-2016, 12:42 PM | #2 |
Re: Front Cab Support Frame Mount
This is my 61 4x4 frame but should be the same as the cab has some adjustment when aligning up the fenders/bed etc. Disregard the switch, it was used for eng break-in (no cab on the tk)
1961 chevy K10 my build is------------61K10 build |
08-31-2016, 12:58 PM | #3 |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-31-2016, 01:15 PM | #4 |
the elongated hole is only on the pass side. has your old ones rusted out a bit?
ron |
08-31-2016, 02:12 PM | #5 |
08-31-2016, 05:15 PM | #6 |
then you will just have to cut the top section out and put a new piece in. 1 1/4" hole saw and a bit of clean up to the desired size and you are away
I am just on th3e way out the door to go see the doc so I will post you some pics later I had a pacemaker installed mon afternoon ron |
08-31-2016, 08:24 PM | #7 |
08-31-2016, 09:29 PM | #8 | |
Had a triple bypass in April and still thawing out from the freezing. Be careful, but enjoy yourself till you start feeling better. Norm
08-31-2016, 09:46 PM | #9 | |
ron |
08-31-2016, 11:31 PM | #10 |
Glad you're feeling better. Watch out when your wife revs up the microwave!
08-31-2016, 11:50 PM | #11 | |
Those have all been eliminated years ago. one has to keep any electric power devices twelve inches away, not use a welder over 160 amps and be aware where any under 160 are. it is all common sense cell phone on right ear and mounted on right hip. metal detectors are a real no no. it is interesting. I had real problems just in the week before climbing the 19 steps up to the mezzanine in my shop. to take deep breaths in bed in the 4 hour recovery period was remarkable ron |
