Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-22-2016, 02:53 PM   #1
Super73
Super73's Avatar
Winner Winner - Chicken Dinner....
Went to The Red List Truck Wars in Bakersfield this weekend. Ended up winning:
King of Trucks
Fasted ET
Fastest GM
Towed down on Sat afternoon and it was HOT. My tow rig was showing temps in the 101-103* range. Once there I decided to run the Sat evening race (open to everything) for some test hits since I have never been to Bakersfield and the converter was recently tightened up. Truck was on the radial (315/60/15).
Right off the trailer NA the truck hiccuped about 40' out and went 10.99 @ 124.5 with a 1.67 60' Pulled in to the pits and cleaned up a rich tune.
Next pass NA let go of the brake and it fell on its face (almost stalled), lifted and hit it and it took off. Went 10.91 @ 124.6 with a high 1.7x 60' Truck ended up turning off on the return road. I tried starting it again and could hear the fuel pump freewheeling not building any fuel pressure Tow it to the pits and force the pump on via my laptop. It tries building pressure but wont keep consistent, bouncing from 10-65psi (65 is what I run). We tried moving the adjustment on the regulator wondering if there was something messing with the diaphragm and that seemed to help a little. I open the fuel cell cap and noticed bubbles coming out the return line. Hmmm are we vapor locking the E85 due to the heat? Truck was in the enclosed trailer for the 4 hour tow and I have to figure ambient temp was well in to the +12x* range. I add 5 gallons of fresh E85 that has been sitting in the shade and bubbles go away
Make another NA hit and truck responds well with a 10.7x @ 125mph.
Decide to make one more hit in preparation for Sundays truck event and put a 200 hit on it. Being I was melting from the heat, I figured I would be conservative on the timing and pulled 12* of timing, I did not want the motor to feel the same pain I was. Set the N20 ramp at 50% initial and all in by .3 seconds. Truck went 9.60 @ 138.x with a 1.45 60'.
As the gates opened on Sunday, I noticed most the trucks coming in were more towards the truck show and were on a true street tire. I decided I would be better off putting the big tire on (32x14.50) as I wasn't sure how well the track would fair.
First pass was at 11am and it was already 90* out. I changed the N20 ramp to 100% out of the hole but kept the 200 hit in it with the same timing. Truck went 9.79 @ 138.x
Second pass I pulled an additional 4* timing (16* total) and added the other kit for a total of 300 out of the hole. Truck went 9.49 @ 141.x with a slight lean spike out of the hole causing the PCM to pull another 3.5* timing for for 1.2 seconds.
Got back to the pits and added fuel on the hit with no other changes. Truck got loose about 60' out but staid straight, pass was feeling a bit faster than the last. Truck popped twice right as I crossed the traps and shut off. I coasted to the return road, went to restart it and had now power, all electrical is out. Walked to the time booth 50' away and the timers has a fault and no slip printed. Being it was 2:45 and the event was over at 4:00, I towed it back and called it a day.
All in all I am happy with how the truck ran, but I think a cool can will be the next upgrade since I don't class race. Also going to have to pull the verter and likely move to a 9" from the 8.5" I have now. I will look a the electrical in the next week of so.
First time getting any prize money, $500 in total. That made me happy
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-23-2016, 01:19 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Winner Winner - Chicken Dinner....
That's the one place I miss going to Famoso Dragway, had lots of fun the years I went one of which was a Super Chevy Show. I'm happy you had fun and kicked ass.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-23-2016, 09:53 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Always good to win . Kinda what we do it for .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-28-2016, 04:59 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
WTG Shaun!!! Well deserved win and kinda makes all the BS of hetting here worth while hu!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-29-2016, 10:26 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Very cool! Congrats!
I read you guys about racing and it makes me want to get back in the game. But I already have 2 other money pits (fishing boat and an RV) besides the truck I am currently building.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-01-2016, 09:23 AM   #6
kpeztruck
kpeztruck's Avatar
Great job on the win!! Glad to see you still at it and doing well. Mine has not seen a track in two years now. Just a season of life. Ill be back at it in time.
kpeztruck is offline   Reply With Quote
