Old 09-01-2016, 12:03 AM   #1
rthompson339
Robyn's '76 "steering box"
Does anyone know if a 1980 steering box will fit a '76? In the pics they look nearly identical.
The local parts house can only find an '80. Please let me know ASAP, I need to order so I can get it Friday.
rthompson339 is offline   Reply With Quote
Old 09-01-2016, 02:30 PM   #2
barry1982
Re: Robyn's '76 "steering box"
Yes, I believe you should have no problem. I'm not positive, but you may run into problems between 3/4 ton -1/2 ton steering boxes. But 1/2 to 1/2 should be okay. I once installed a steering box from a 78 onto a 72 without much trouble.
barry1982 is offline   Reply With Quote
Old 09-01-2016, 02:41 PM   #3
72shorbox
can't remember off the top of my head but they changed to metric fittings about that time so check that out. Someone will sound in on that.
72shorbox is offline   Reply With Quote
Old 09-01-2016, 11:50 PM   #4
80SPORT
80SPORT's Avatar
Correct...80 up used metric/O ring fittings
Other than adapting the hose all will fit (2wd and 4 wd are different)
80SPORT is offline   Reply With Quote
Old 09-04-2016, 12:08 AM   #5
rthompson339
Thank you for your replies about the steering box. I got a remanufactured one that did NOT have the Poppet valve installed is that normal? The kid at the parts house was at a loss when I asked him. Must not have been his department.
