Closed Thread
Old 09-03-2016, 08:42 PM   #4251
In The Ten Ring
Re: What did you do to your truck today? Chapter II
I got the last of the fuel line hooked into the carburetor.
I also put the air cleaner onto the top of the carb. Not much left to do now.
In The Ten Ring is offline
Old 09-03-2016, 10:22 PM   #4252
Zeroman
Zeroman's Avatar
Actually yesterday, but got the engine and transmission married together, then got them mounted in the chassis.
Zeroman is offline
Old 09-03-2016, 10:49 PM   #4253
70STOVEBOLT
70STOVEBOLT's Avatar
Ran new harness for power windows and finished converting the driver side regulator to accept the motor. Also mounted the switch. Then attempted to install the window and got it bound up and cracked it. Also painted my fuel psi regulator mounting bracket.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 09-03-2016, 11:49 PM   #4254
toolboxchev
Man that looks nice, old skool style! I finally tuned up my engine bumping up the timing to 14 degrees advance like everyone says with the ethanol fuel.
It sure burned the carbon out!
toolboxchev is offline
Old 09-03-2016, 11:57 PM   #4255
Zeroman
Zeroman's Avatar
Thanks toolboxchev! That's exactly what I like..old skool style.
Zeroman is offline
Old 09-04-2016, 12:51 AM   #4256
suburban99
suburban99's Avatar
Borrowed some tires and wheels off a Tacoma to see what they look like...
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline
Old 09-04-2016, 02:28 AM   #4257
rustytruck50
rustytruck50's Avatar
Replaced the master cylinder & starter for a trip to KC next weekend....just call me the "Post-Shade-tree Mechanic"
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 09-04-2016, 07:50 AM   #4258
BugzC10
BugzC10's Avatar
Size looks just right!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 09-04-2016, 09:25 AM   #4259
SoCoC10
SoCoC10's Avatar
Finally finished working on everybody elses trucks and got some work done on my truck...
I'm starting a build thread for it too.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 09-04-2016, 11:55 AM   #4260
rustytruck50
Good looking truck!
-Doug
'05 RCSB Sierra 2WD
Old 09-04-2016, 02:45 PM   #4261
Jarvis-69 GMC 1500CK
Got most of the wiring fixed, dropped it off at my uncles t fix the door hinges (Will see if i can be present to show how he did it)
Jarvis-69 GMC 1500CK is offline
Old 09-04-2016, 03:44 PM   #4262
rustytruck50
Guys i thought i,d share a fyi on small block chevy starters. If you want your old chevy truck to crank over like a race horse even on the hottest days and even with the heat off headers dont fool with stock 67-72 chevy truck starters. Get a starter off a 69-70 chevy corvette with a lt-1 small block there hi-torque starters. These are hi-compression engines. I have a 383 sbc with 10-1 compression and this oriellys life time guarantee starter #03-0367 really spins it over and its only $44.64. Plus you wont have that dreaded gear reduction whine. Hope this hhelps somebody out.
I followed this tip & it works great!!!! Thanks BCOWANWHEELS!!!!!
-Doug
'05 RCSB Sierra 2WD
Old 09-04-2016, 03:44 PM   #4263
rustytruck50
Got this from BCOWANWHEELS......"Guys i thought i,d share a fyi on small block chevy starters. If you want your old chevy truck to crank over like a race horse even on the hottest days and even with the heat off headers dont fool with stock 67-72 chevy truck starters. Get a starter off a 69-70 chevy corvette with a lt-1 small block there hi-torque starters. These are hi-compression engines. I have a 383 sbc with 10-1 compression and this oriellys life time guarantee starter #03-0367 really spins it over and its only $44.64. Plus you wont have that dreaded gear reduction whine. Hope this hhelps somebody out."
-Doug
'05 RCSB Sierra 2WD
Old 09-04-2016, 06:25 PM   #4264
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bought an OEM replacement steering wheel I said I didn't need.
Put my engine into hibernation. Been saying I'd do that for 9 months. I didn't wanna, and discovered you can remove maybe 35% of the parts without it. I ran out of stuff to do. No excuses until this is torn down. I'm hoping that comes by early spring, right in time for 5 months of refinish.
Tomorrow I remove the alternator, power steering and fan. Then reinstall the high horn to determine how I'll install the NOS coolant tank. Don't much care for the hose-line to the nipple bumping the horn harness "per instructions". It's real close anyway. I'll likely drill the "correct" holes into the core rail, then add a bracket "extension" for the mounting bracket. IMO it would look cleaner as well. There's a lot of space in that LH front corner. Kinder to the tank as well.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 09-04-2016, 06:49 PM   #4265
72c105speed
Working on getting my truck down to bare cab, found problems along the way...
72c105speed is offline
Old 09-04-2016, 06:50 PM   #4266
72c105speed
Old 09-04-2016, 08:30 PM   #4267
Possmguts
Possmguts's Avatar
Originally Posted by TwoFiftyShifter View Post
Got the big n littles on
Dang.. what is that bed? Like 20 feet?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 09-04-2016, 11:44 PM   #4268
toolboxchev
Originally Posted by 72c105speed View Post
Looks like something missing there, that would account for more than 90 % of them, used and put away wet!
I feel for you there, the stuff some others do. I have had my share of WTF?
Old 09-05-2016, 03:04 PM   #4269
1968aj
Test fitted the bucket seats today. I don't think they look right with rubber floor mat. trying to decide on what color carpet to get. don't want black carpet . need something to offset all the black .
1968aj is offline
Old 09-05-2016, 03:31 PM   #4270
Possmguts
Possmguts's Avatar
Hate to say it.. but the threads in that crank is probably stripped... I wouldn't be surprised if the PO tried to use the bolt ti install a balancer and ruined the crank.. and then went to the hammer... seen it a hundred times...
Old 09-05-2016, 06:44 PM   #4271
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Didn't do anything today but yesterdays road trip was productive. Gotta say thanks to my wife for buying a Dodge Grand Caravan and be willing to use it on my parts safaris.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 09-05-2016, 08:00 PM   #4272
1969_CM2590D
1969_CM2590D's Avatar
Actually I've dons a lot today and the whole weekend.
This Labor Day weekend i finally got back to my '69 305E 2500. The truck has 41K+ on it with manual everything. Coming form Alabama it was one of the last pickups to have no emission controls. With all that in mind, it's incredibly simple and brings a whole new meaning to the term serpentine belt.
I did the 4412 swap with the 1937 adapter when I got the truck the truck a few years ago. It never would idle right often not holding an idle as well as a hesitation beast on giving it the gas. I get frustrated over time. As time went on, I realized I had misread the instructions for installing the carb and tightened things to ft/lbs instead of in/lbs. A few moths ago I ordered new gaskets for the adapter and carb for when I could get to it, putting off fears I might have warped anything.
Saturday, I put the new gaskets on and once the dry carb got gas, things improved over 1000%. Toning the idle down from what was probably 1000+ RPM, it held its idle much better at the specced 500 RPM.The truck idled for over a half an hour. In the driveway, I gave it the gas and it accelerated smoothly. I let i sit for a few hours and with a flick of the key it fired up. Same thing the next morning. So a lot of problems solved. It still had a slight miss, though, so today I timed it by by feel, turning the dizzy until things were much smoother and reset the idle speed.
With all that in mind, I took it into town for a road test. No stalling and a decent idle, but going up a hill under load there was hesitation. so I got back home and looked into setting the idle mixture. Holley says to use the manifold vacuum for that- so there was one error I'd been making. I have been using the ported vacuum on the 4412 fer setting it up- Holley instructs to use that, but just for the vacuum advance. The advance was checked a while back and was OK. I came across threads which got me looking into using manifold vacuum for the advance. More to look at as time goes on.
With my non-emissions 305E what I've come across on the net tells me I should be using manifold vacuum, not the emission controlled ported vacuum.
Dennis Nichols
1969 GMC C2500 305E V-6 The Mule
1986 Toyota 4Runner
1959 MG MGA Coupe
1969_CM2590D is offline
Old 09-05-2016, 08:35 PM   #4273
Possmguts
Possmguts's Avatar
Came within an inch of pouring gas all over it and torching it... she was not my friend today. I rebuilt and converted the column from a column auto to a floor auto, and I just cant get the slop out of it... I know its been done by someone in here, and I would love to be able to find his thread to see what Im missing. On another note, some of the panels are heading to the paint shop tomorrow...
Old 09-05-2016, 09:15 PM   #4274
72.4me
New tires, front coil springs , shocks and bushings
72.4me is offline
Old 09-05-2016, 09:33 PM   #4275
72c105speed
Damn I hope not! It's a good running engine!
Closed Thread
