Old 08-29-2016, 11:56 AM   #1
cgster
Vacuum Port For Power Brakes
I'm going to use my intake for the vacuum on my power brakes. What does the fitting look like that I will need for the intake? Thanks.
cgster is offline   Reply With Quote
Old 08-29-2016, 12:32 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Vacuum Port For Power Brakes
Here's a start. It depends on what other options your truck has in addition to power brakes. GM used the same intake port for auto trans and A/C.
http://www.parts123.com/corvettecent...r=&part=vacuum fitting&searchtype=50
FirstOwner69 is offline   Reply With Quote
Old 08-29-2016, 12:35 PM   #3
webfoot
I got a Spectre chrome fitting with a 90 degree elbow. Autozone had it in one of the aisles.
Looks kinda like this:
https://www.amazon.com/Chrome-Alumin.../dp/B00TBNEPZS
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-29-2016, 12:42 PM   #4
cgster
Great, thanks for the links guys.
Old 09-01-2016, 09:39 AM   #5
cgster
Just wanting to make sure this is the right port that I can use for the vacuum on the Power Brakes:
Old 09-01-2016, 09:44 AM   #6
71c10tim
yep, that is the right port.
71c10tim is offline   Reply With Quote
Old 09-01-2016, 10:03 AM   #7
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
I think you will find engine coolant under the plug circled...
CaptRMW is offline   Reply With Quote
Old 09-01-2016, 10:11 AM   #8
cgster
So this wouldn't be the right port to use?
Old 09-01-2016, 10:58 AM   #9
BugzC10
BugzC10's Avatar
Directly behind the carb there should be a port in the intake manifold to connect vacuum as in this picture ( brass fitting) or at the base of your carb. I have mine attached to the base of the carb..line just above the brass fitting.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 09-01-2016, 11:01 AM   #10
cgster
Ok I'll look later today and find the port directly behind the carb on the intake. Thanks.
Old 09-01-2016, 11:15 AM   #11
BugzC10
BugzC10's Avatar
There should be a port on the back of your carb with a large nipple for the brake booster connection...like mine. You can use either the manifold direct or carb. If you have an automatic trans, the tranny modulator is probably already hooked up to your manifold..
Old 09-01-2016, 12:47 PM   #12
FirstOwner69
To clarify...
The earlier trucks (before 1971?) did not have a port on the back of the carb for brakes. The factory used the port on the rear of the manifold on the passenger side. They also attached the vacuum lines to the transmission modulator and A/C canister to the same port (if equipped with auto trans and A/C). Here's a pic of where mine is on my original '69 350. However, I'm not sure if the fitting is what would have been on a factory power brake setup with A/C and auto since I had the power brakes added by the dealer as a condition of original sale in 1969.
Old 09-01-2016, 01:37 PM   #13
ck5566
First what is needed is to know what Alum. Manifold or Aftermarket Alum Manifold he's using. I have two, one is on my truck it is a Edelbrock Performer Manifold with a screw in tap at the front driver side and that is for water (just like circled) but in front, and one tap for Vac/air behind Carb on raised mount for Carb. My other is a Edelbrock Torker and again same location under backside of Carb. only one air/vac port on it. I belive that any air/vac port of a Manifold is whats needed. Others will chime in if I am wrong.
ck5566 is offline   Reply With Quote
Old 09-02-2016, 12:17 AM   #14
cgster
Ok, here is a new picture. Is the circled port the correct one for the vacuum on the power brakes? Thanks.
Old 09-02-2016, 07:24 AM   #15
biketopia
Yup, that is the correct port you need.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 09-02-2016, 07:56 AM   #16
BugzC10
BugzC10's Avatar
YES!!!
Old 09-04-2016, 10:18 AM   #17
cgster
What tool is needed to remove that plug so I can screw in the vacuum fitting? Thanks.
Old 09-04-2016, 12:27 PM   #18
FirstOwner69
Looks like it's hex. If so, one of these in the proper size should do the job assuming it's not metric.
http://www.harborfreight.com/9-pc-38...set-67884.html
