Re: 64-66 4x4 Front Spring swap with 73-87
60-66 Nut
You are going to have to change the spring hangers and shackles both front and rear to the '73-'87 units.
#4 | |
Originals look like they are 44 inches & look like they are centered on the spring bolt. Newer ones are 47 & I am thinking I could just off set the center olt location. It appears there is plenty of room on the front frame for the newer brackets. I might just mock this up & bush out the rear of the front spring. I am also considering jut moving the spring perch hole on the front end axle it self. Last edited by Auctioneerhere; 09-07-2016 at 10:33 PM. |
