![]() Join Date: Jan 2002
w/tb k-30 gas filler neck
i have a 82 chevy k-30 truck that has a 1 side only fuel tank that needs a gas filler neck w/mounting plate -this piece has a half round dish id call it- that has the gas cap in it ! mounts on a couple of risers off the truck drivers side frame/a vent and gas filler hose hooks to it ! mine is very rusty -not worth repairing ! does anybody have a nice one ??? thanks
Re: w/tb k-30 gas filler neck
I have this.
im sorry maybe i didnt describe it right ! mine has a 90 degree elbow at the top and a plate on the back side ! it is a cab & chassis set-up w/ a masons box /will try and post pic tomorrow thanks guy !
#4 | |
Junior Member
I had to repair my filler neck not long ago. My problem appeared to be that someone had used radiator hose instead of fuel hose and the hose had split. Fortunately, I didn't have to replace the fill neck but I did spend an afternoon cutting and modifying things to enable remounting - works better now. If your tank and fill neck are like mine, the vent is 5/8 inch and fill hose is 1 & 3/8 inches. Please make sure, if you are replacing the hose(s), that you use fuel rated hose. I found this link when searching for info: http://www.fillernecksupply.com/?gcl...FQYuaQodIyINHQ , maybe it has what you need. Good luck,
Have fun, Don |
82-up should be 2" filler hose/tank neck
81-back should be small neck. better measure to be sure. Sorry, I can't help on part
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
