09-06-2016, 10:03 PM | #1 |
Frame straightening
so my frame is bent on my original shortbed 72' k10. Im not having much luck finding another original frame. I took it to one body shop and they said its bent 1" in the diamond in the front and the right frame horn sits lower then the left. They said its not worth fixing.
I would like to get another opinion, they didnt actually have the specs for my year of truck... So can ANYONE recommened a reliable place that will straighten just the frame itself here in Utah or close to Utah? I just want it done and I want it done right! Ive called around and people either want the whole truck to be there with them, or there frame rack is to small, or they dont have specs for a truck that is this old. I NEED HELP! |
09-06-2016, 10:16 PM | #2 |
All about them K’s
Re: Frame straightening
Genes frame and alignment Farmington NM. we use them at work for suspension related stuff but they will tackle it all. I see your north of salt lake so it's a drive for sure.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-06-2016, 10:41 PM | #3 |
Of course it's worth straightening! I can't help you on a place to straighten it, but keep in mind once straightened, anything that got tweaked with it will then be crooked and need alignment.
09-06-2016, 11:04 PM | #4 | |
09-08-2016, 12:16 PM | #5 |
I just went through this with my project. I have been driving around to body shops for the past year trying to get the frame straightened on my C15 and they either knew someone else who could do it, or they said to bring it back with the body off, or their rack couldn't pull it. Bottom line, no one wanted to touch it or they were too busy with insurance work.
Then I found a straight frame on craigslist and picked it up for $150. Same year and model as my existing frame. Came with a 12 bolt rear end that I will be able to sell off and make some money on this endeavor. Just painted it last weekend and will start the transfer this weekend. My wife just rolled her eyes when I told her what I was going to do! I know it is not what you want to hear, but your best bet is to locate another frame and do a swap. You will make out in the long run. I was getting quotes in the $500 - $1000 range, but they were not firm.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
09-08-2016, 12:42 PM | #6 |
There's a BIG difference between finding a 2wd lwb frame and finding a swb 4x4 frame, both in the number of them available & the cost.
It doesn't sound like your frame is all that bad, I'd keep looking for the right shop, even if it's a bit of a ride, and get it straightened. This way you also keep the trucks originality & the vin #'s match. Just My 2 cents ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-08-2016, 01:12 PM | #7 |
09-08-2016, 05:15 PM | #8 |
jonesky2, I was impressed with these guys. http://www.bountifulcollision.com/
They straightened the front of our longhorn frame last year and were very reasonable. I did supply them with the following dimensions from the 1972 Chevrolet Truck Chassis Service Manual 10-30 Series. Pretty sure your specs are the KA105 line.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
09-08-2016, 05:26 PM | #9 | ||
If they have a Chief E-Z Liner or similar that's an easy fix. Good luck.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
09-08-2016, 05:40 PM | #10 |
It takes longer to set it up and chain it down on a frame table than it takes to fix it , like previously stated you have to find a shop that actually knows how to use a frame machine , many times you'll see a frame machine sitting in a body shop covered in dust and rarely used . Years ago I had to have one in the shop to qualify for insurance work . In today's world they total the bent trucks . Try the oldest body shops in town first . New body men of today don't even know what a portapower is .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-08-2016, 05:43 PM | #11 |
Guys that know how to and more importantly willing to straighten frames are a dieing breed. Alot can be done with a come along and a jack if you have some thing to tie the frame down to. Heavy equipment trailers work great cause they have lots of tie points and are WAY stronger than a pickup frame.If you try the job yourself just remember you have to straighten first and pull the diamond out last. A little push, pull, beating,and lot of double checking with the tape measure you can get there. Fortunately the dimensions for these trucks are easy to find. Good luck.
