Old 09-06-2016, 04:46 PM   #1
chrismoore701
chrismoore701's Avatar
Small tach
I am thinking of adding a tach to my truck but do not want one on the dash or the column. Has anybody ever found one that will fit in one of the small holes in the cluster? Any other ideas?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 09-06-2016, 05:40 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Small tach
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-07-2016, 12:23 PM   #3
akart
Re: Small tach
Auto Meter makes one #2698. Bought one, fits in the cluster. Going to put it in the clock spot where there is no clock.
akart is offline   Reply With Quote
Old 09-07-2016, 02:45 PM   #4
logbuilder69
Re: Small tach
I saw someone mention this is another thread. It looks like what I am interested in. It mounts where the big fuel gauge goes.
http://www.gmsports.com/content/new-...and-gmc-trucks
logbuilder69 is offline   Reply With Quote
Old 09-07-2016, 03:46 PM   #5
rich weyand
rich weyand's Avatar
Re: Small tach
Here's my install story for the combo gauge.
Note that they have a version with the old typeface if that's what you need. You have to ask for it.
http://67-72chevytrucks.com/vboard/s...d.php?t=629131
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 09-07-2016, 06:32 PM   #6
chrismoore701
Re: Small tach
Do you have a picture?
Chris
Old 09-08-2016, 12:23 PM   #7
akart
Re: Small tach
Here is a photo this a 2 5/8 diameter meter
Old 09-08-2016, 05:55 PM   #8
Ski-me
Ski-me's Avatar
Re: Small tach
I put one behind the lower bottom section of the cluster....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-08-2016, 08:16 PM   #9
chrismoore701
Re: Small tach
How hard was it to install? Did you just slide it in? Do you clamp it from the back side? Or does the bezel hold it in?
Chris
Old 09-09-2016, 09:51 AM   #10
Ski-me
Ski-me's Avatar
Re: Small tach
It does take some work to get it in there. I had to cut out the back of the cluster to allow room for the whole tach housing. Then used some metal strips and bent them enough to position the tach correctly. Then I had to also carefully cut out the bubble, clear plastic part of the cluster that covers the gauges too.
The glass from the tach sits flush with the outermost gauge bezel and looks nice. Just a lot of trial and error to get it all looking good and mounted securely. I may have more pictures at home....
- Jeff
Old 09-09-2016, 10:04 AM   #11
Ski-me
Ski-me's Avatar
Re: Small tach
Some more close up shots....
It is just slightly off center so that when you view it from the drive's head position, the whole gauge is visible and looks centered at that vantage point.
- Jeff
Old 09-09-2016, 10:31 AM   #12
chrismoore701
Re: Small tach
Thanks guys
Chris
