Old 03-19-2004, 01:29 AM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
guys my gas guage isn't working
last week my fuel guage quit working on me. First i thought it was a fuse, there isn't one. then i thought it was my hot wire out of the box to the guage and i put it on another terminal and it made a small spark, no big deal, and it hasn't worked since. you guys tell me.
When the key is off the guage goes extremely slowly up from E to like 1/16th of a tank and as soon as you turn on the key it pulls back down to E.
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-19-2004, 03:17 AM   #2
doughby82
doughby82's Avatar
cant help ya on this one,but the 72 i just sold when ya turn the lights on the gas gauge would drop past empty,and on my 68 it drop way below empty when its cold outside(under 30)but as soon as the cab warms up it moves to where it supposed to be.i think someone had a good post on the gas gauge before ill see if i can find it
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 03-19-2004, 03:39 AM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Check the brown wire from the tank sending unit which runs under the door sill on the driver side to see if it's grounded.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 03-19-2004, 11:29 AM   #4
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
check the connection on the gas sender. Sometimes it works its way loose.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-19-2004, 11:38 AM   #5
Putter
More Cowbell....
Putter's Avatar
This most likely will not help in any way, but have you ever see the movie "SLINGBLADE"? Maybe you oughta' check and see if she ain't got no gas in it. Just my $.02
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 03-19-2004, 12:00 PM   #6
whitesswj
Embrace the Redneck
whitesswj's Avatar
I filled up on the day it quit. and you and i both know that once on E you better start lookin for a fillin station.
'01 Camaro
Old 03-19-2004, 12:31 PM   #7
Putter
More Cowbell....
Putter's Avatar
My gauge was acting up a few weeks back, but when my sending unit is not connected, my gauge goes up waaayyyy past full. Then if I re-connect it, it goes back to normal. Mine was just loosing connection.
Old 03-19-2004, 12:45 PM   #8
fast14
fast14's Avatar
While we're on this subject, how do you know if the gauge is getting power?? Mine doesn't move at all even if i remove the wire from the sending unit.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 03-19-2004, 01:36 PM   #9
orangeuavol
GO VOLS!
orangeuavol's Avatar
ask jhow66
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 03-19-2004, 06:02 PM   #10
jhow66
jhow66's Avatar
Go to search and type in "jhow66"--read the thread on Brodykelly--this should help.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-19-2004, 07:06 PM   #11
cdowns
cdowns's Avatar
if you've got 12volts to the sender and you have a GOOD ground from the sender to the body i'd think you have a bad guage
Old 03-19-2004, 08:08 PM   #12
jmanz69
Careful, they attack...
jmanz69's Avatar
That wire going to the sending unit isn't a 12 Volt wire. It's a sensing wire. If you put 12 Volts on it, you probably blew your sending unit. The 12 volts goes to the gauge, then out at a lower voltage to the sending unit. The gauge reacts to how much of a voltage drop is on that wire thru the sending unit. Sounds like you fried it man. I would look for another sending unit. You can take yours out and measure with a meter from the terminal for the wire to the outside of the sending unit (ground) and see if there is 0-110 ohms when you move the float up and down. If there is, then you blew your gauge. Good luck.
Here is a pic of the wire diagram how it works.
jmanz69 is offline   Reply With Quote
Old 03-19-2004, 08:12 PM   #13
jmanz69
jmanz69's Avatar
here it is.
