Old 09-09-2016, 12:27 PM   #1
WarMonger
WarMonger's Avatar
grill bumper swap
Sooooooo did a grill and bumper swap for a guy. everything went as planned, but that bumper took lots of shims. Now is that because of poor made parts, bent tweeked frame or just a combo of both?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 09-10-2016, 11:59 PM   #2
Ryan5O
Re: grill bumper swap
Im curious as to the length of those two bumper brackets. The previous owner of my pickup mounted an aftermarket chrome bumper and currently only one of those brackets are being used. I'm missing one. The other day I went to a junk yard and pulled the missing part I needed. To my surprise, when I attempted to mounted it, I found out that it was two short (around an inch). The stock part from the junk yard is shorter than the mount currently in use. Im wondering if the brackets your using are the short versions I recently found, which caused you to have to shim it up. Did you use the shims on the frame end or on the bumper end?
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 09-11-2016, 05:31 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
67-70 trucks used shorter outer brackets as they bolted right where the parking light is on a 71/72. When Gm put the larking light in the bumper in 71, longer outer brackets were needed since the bolt is now further toward the edge of the bumper. (67-70 brackets do not interchange with 71/72 brackets.)
WIDESIDE72 is offline   Reply With Quote
Old 09-11-2016, 02:43 PM   #4
Ryan5O
Good to know, I suspected such.
Old 09-11-2016, 07:56 PM   #5
Shinysideup
Shinysideup's Avatar
Well judging by the MANGLED bumper you took off Id suspect things were bent brother.
Shinysideup is offline   Reply With Quote
Old 09-12-2016, 10:23 AM   #6
WarMonger
WarMonger's Avatar
Yeah, there was a lot of ... persuading going on.
1970 C20
-_--_--_- ______
1972 K5
