03-18-2004, 02:57 PM | #1 |
THE QUICKER FIXERUPER
New ECE center X member
I was checking out the early classic enterprises site and came across this Im suprised nobody came out with it sooner. the link is
http://www.earlyclassic.com/centerxmember.html |
03-18-2004, 02:59 PM | #2 |
www.73-87chevytrucks.com
SWEET!!!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-18-2004, 03:07 PM | #3 |
Boy, That takes care of a whole lot of problems at one time. I will be ordering that this weekend.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
03-18-2004, 04:13 PM | #4 |
Dang, that is nice. I was going to make one out of square (rectangular) steel tubing. That saves alot of work.
03-18-2004, 05:00 PM | #5 |
67 is sold
Nice
03-19-2004, 12:10 AM | #6 |
Sweet. I had already cut mine to run my exhaust through it.
Chris
Chris click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
03-19-2004, 01:21 AM | #7 |
I received the x-member last week. I am totally impressed with the quality from Dave Clark and ECE. Nice semi flat black powdercoat finish and trick grade 8 hardware. I will post pics of my frame next Monday with this temporarily installed. I have already tack welded cross braceing to the frame to prevent any flex or movement since this piece is a vital part of chassis rigidity.
03-19-2004, 05:01 PM | #8 |
Will the exhaust pipe hit the e brake cables when running the exhaust thru the cross member ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-19-2004, 05:33 PM | #9 |
F.A.S.T. president
Dammmmm thats nice.....can you buy me one....
If my frame wasnt already done I would buy one. |
03-19-2004, 07:12 PM | #10 |
According to ECE this does not interfere with brake cables.
