Old 09-14-2016, 10:04 PM   #1
Jimbucci
49 GMC on s10 frame th4OO help
Building a 49 on s10 frame with a pretty radical 383 stroker. I have a th400 lined up for 150 bucks but its the long shaft not the short. Anyone know if it will work?
Jimbucci is offline   Reply With Quote
Old 09-15-2016, 01:05 AM   #2
iowaboynca
iowaboynca's Avatar
Re: 49 GMC on s10 frame th4OO help
hmmm....might be a better question for the engine/drivetrain section. Good luck w/your search.
But then again i'm sure someone might be able to answer your question.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-15-2016, 11:51 AM   #3
joedoh
joedoh's Avatar
long tailshaft? not sure it matters long or short, only should matter to driveshaft length really. since you are moving the engine back you will need to make a trans crossmember anyway, and make a driveshaft anyway.
thats just my cruddy opinion based on my limited understanding of the long vs short tailshafts, which is a big deal to use in a chevelle but not such a big deal in a truck you are making new engine and trans mounts and driveshaft.
and I will say it in pittsburghese: get dahn nere an nat and yinz can use the tranny, I's stunned!
Old 09-15-2016, 02:41 PM   #4
Jimbucci
Your pittsburgese is very fluent lol. I bought an ezchassis kit with a 400 cross member. As long as the mounting points are the same I think I should be good. Ed didn't ask me which tailshaft I have so I assume the cross member bolts in the same spot. This is my first Chevy build so I'm not sure on their trannys. Everything up till now had a c6 on it and the tailshaft of those always mattered
Old 09-15-2016, 03:20 PM   #5
joedoh
joedoh's Avatar
yep you should be golden! I grew up in the north hills, go stillers!
Old 09-15-2016, 04:41 PM   #6
mr48chev
mr48chev's Avatar
Since you will have to build a driveshaft anyhow the longer tail shaft is just that = longer.
If you were hardcore on having a short tail shaft you could pull the guts out of the trans, swap tail shafts and extension housings and go again. It may not be worth the effort and cost though.
My ongoing truck projects:
