Old 09-16-2016, 07:50 PM   #1
webfoot
Rear leaf spring modification/removing a leaf
The rear springs in my 70 are off a 73-87 1-ton and are QUITE stiff, especially with a 88-98 fiberglass step bed on it, they aren't really compressed much at all. (I measured 2" of shock travel between sprung and unsprung.) If I could remove a leaf I think they might be a world better, but the pack is riveted and banded together. Has anybody ever done this before? Or is a new set of springs in order? I was pricing skyjacker softrides and they are about $320 EACH.. ouch.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-20-2016, 12:34 AM   #2
Dsuper5
Dsuper5's Avatar
Re: Rear leaf spring modification/removing a leaf
Well Webfoot you are in for a interesting ride! I started out with a 64 Sub 4x4 and put 83 suburban front springs and hangers in, the rear have a 62 inch chevy 1 ton 1999 set up ( and shackle flip and hangers) Bilsteins 5160 on all 4 corners and its good but not good enough..
Ib used a grinder and drill to take the spring packs apart to where i thought it would work for me. 2000 miles later i know i need stiffer springs or more leafs1
It is a trail and error try and drive change and switch to the point it works for you, there is no one way solution to it once you started changing stuff!
I post some pics..
Dsuper5 is offline   Reply With Quote
Old 09-20-2016, 12:41 AM   #3
Dsuper5
Dsuper5's Avatar
Pics
Old 09-20-2016, 10:56 AM   #4
kwmech
If it is a true 1 ton spring pack, you can remove about 3 leafs from it. Not all of them are riveted. Just remove the center pins and slip out the ones you do not want.
