Old 02-24-2014, 06:34 PM   #1
Scwhitear
New guy with a 1968 k20 burb.
So I just received a gift in the form of a 1968 Chevy K 20 suburban. Just needs a little bit of bodywork. Paint and some new tires. Has a new 350 and the tranny had just recently been going through.it also has the interior from a newer Tahoe. I have always been a fan of the 67 to 72 trucks. But now that I have a suburban I absolutely love it. But I am also new To this forum and to this type of vehicle. If anybody could give me some info that would be great. I have been told that the 68 K 20 is somewhat rare? Just wondering the value of these suburbans? I would like to put a 3 or 4 inch lift on it and run 33's or 35's not sure yet... Bur I have read that it is hard to find a lift because of the back leaf springs are are longer or shorter than 69-72 . Idk! But any information would be helpful. I plan on starting the build sometime this year. I would put pictures up but still trying to figure out how to on my iPhone. As soon as I get back to my laptop I'll post some pictures.
Scwhitear is offline   Reply With Quote
Old 02-24-2014, 10:08 PM   #2
vectorit
What?
vectorit's Avatar
Re: New guy with a 1968 k20 burb.
Welcome to the forum!
The 1968 K20 Suburban is one of the lowest production Suburbans, documentation is vague but numbers show only 299 of that model rolled off the line in 1968.
Take some time to browse the build section, and you will find guys like yourself neck deep into their projects.
Be sure to share pictures of your new old K20 burb! We love pictures here
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-24-2014, 10:49 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
.. From Iowa, and thanks for signing up. Can't wait to see some pics of your truck.
LockDoc
Leon
Old 02-24-2014, 11:36 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Welcome! Glad to see another 68 K20.
If you want to see 4" and 35s, take a look at the build thread in my signature as it's on 35s in most of the pictures. As far as the rear leaves, I ran stock leaves/shackle with a shackle flip for a 4" lift. Unfortunately the previous owner had lift blocks that bent the stock springs with diesel torque. I'm now running stock rear springs out of an 80s 3/4T Burb (56" length, so 4" longer than most leaves, but still a common size). They are a narrower spring eye so I'm running small spacers inside the frame mount to bushing and 69-up rear shackles.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-25-2014, 12:14 PM   #5
Scwhitear
Wow thanks guys for all the feedback! Can already tell that this forum is going to be very helpful. Also I was wondering if the burbs have any problem areas or common things that might Be a good idea replacing? This is not going to be a show Quality suburban. That's not what I'm going for. I'm going to try to make this thing more of my hunting/camping rig. But still a nice enough I can cruise the family around in it... One of the first things I would like to do as a power steering conversion. Is there anybody out there that makes the kit for that? Or am I going to have to hunt and Frankenstein some things together?
Old 02-25-2014, 02:15 PM   #6
4shongo
Welcome to the forum. Post pics of your ride when you get a chance.
4shongo is offline   Reply With Quote
Old 02-25-2014, 06:51 PM   #7
lowrollin70gmc
Too many projects
I run an adapter plate from Captain Fab to use a 69-up steering box on my frame. A previous owner had just used spacers but I continually snapped mounting bolts. The 79-87(91) have metric o-rings, but you can use them as long as you use a pump from the same year (or change fittings on your pump). Best bet would be to source the pump and box from the same truck in a junkyard. Whenever I pull one I also take at least the bottom half of the rag joint, it's easy to bolt apart and you get the correct spline count.
I like the metric boxes as they can integrate hydro-boost brakes very easily.
Adapter plate, it's intended for earlier trucks, but it works well on 68-down 4wd: http://67-72chevytrucks.com/vboard/s...d.php?t=332923
I'll also throw one of these at you: We all enjoy pictures around here.
Andrew
Old 02-26-2014, 03:12 AM   #8
Scwhitear
Old 02-26-2014, 03:18 AM   #9
Scwhitear
Sorry didn't put them up sooner. Im in the army and i have been training all this month and my phone wouldn't let me upload pictures for some reason. Just got back home today. So here are the pictures i have so far.
Old 03-17-2014, 12:22 PM   #10
Burbs
Where did you get Chevy seats? Hands down the most comfortable, I am looking for a rear bench seat like yours with the built in seatbelts.
Burbs is offline   Reply With Quote
Old 03-18-2014, 02:41 PM   #11
Scwhitear
They are out of a 2004 suburban. Yeah probably some of the most comfortable seats I've ever sat in. I'm not quite sure where they came from I was just recently given the suburban as a gift. But I'm really stoked to start working on it!
Old 03-18-2014, 05:05 PM   #12
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
As far as gifts go, you received a very generous one! Welcome to the board and thank you for your honorable contribution of joining the armed services giving us all the gift of freedom
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 03-22-2014, 12:01 AM   #13
Scwhitear
Yeah i know probably one of the best gifts i have ever received… And thanks for your appreciation for the Military! Really cant wait to start working on it. Got some good plans for this rig.
Old 09-16-2016, 08:59 PM   #14
Scwhitear
So I finally found my original glovebox!
Old 09-16-2016, 10:48 PM   #15
72chevynut
72chevynut's Avatar
Wow, that's a nice one to start with!! I love these ole 4x4's! Thanks for posting the pics.
Michael
72chevynut is offline   Reply With Quote
Old 09-19-2016, 05:16 PM   #16
WannaBe68
WannaBe68's Avatar
Welcome on board, Bro' - spent most of my in-country time between JBLM and Hunter. Got out almost a decade ago...seems like only yesterday and a life time ago!
That is one hell of a gift and I recommend becoming friends with Chris (VECTORIT)on this site...his 68 Sub is probably one of the finest Suburbans out there. He has a few threads around here and one in the Suburban projects that kind-of recaps what he did to his. Good luck with your new Sub!
WannaBe68 is offline   Reply With Quote
Old 09-19-2016, 09:42 PM   #17
In The Ten Ring
What a wonderful vehicle! I love the painted bumpers and 3 speed on the column. I really want something similar but with the "barn" doors.
In The Ten Ring is offline   Reply With Quote
Old 09-21-2016, 09:18 PM   #18
notchbackgta
Holy crap, is that a CRT screen in the back of the console?
notchbackgta is offline   Reply With Quote
Old 09-24-2016, 01:56 AM   #19
Scwhitear
Yeah i'm definitely in love with it! No problem i will be posting more as i go on with the build.
Old 09-24-2016, 01:59 AM   #20
Scwhitear
OHHH YEAH! lol but that center console is no longer in the truck.
Old 09-24-2016, 11:53 AM   #21
Scwhitear
Thats cool. I just got out back in april. JBLM was my last duty station. Had a lot of fun up there but man i'm glad to be out of the rain! lol And yeah i have been stalking VECTORIT'S Burb for a few years now. lol But now that i'm out of the ARMY and have a bit more free time i'm going to start the build.
