4 speed transmission crossmember
Need help..swapping out a 235 with 3 on the tree to a SBC 350 with 4 on the floor with a Saginaw transmission in my 1960 c10. What crossmember am I going to need to use for the 4speed?
Re: 4 speed transmission crossmember
Enjoy your truck
You should not need any crossmember. You already have a 3 speed manual so the clutch set up is the same (a different size disc may be in order) but the trans just hangs off the bellhousing with no crossmember for the tail shaft needed - just like the three speed you already have.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
Even if you do need a different crossmember just modify your existing crossmember to fit. I had a 4 speed and replaced it with a TH-400 and all i did was modify old cross member
![]() Join Date: May 2011
Yup, like Greg63 said, if you use your existing bellhousing mounts, no crossmember is needed. All 3 and 4 speed trucks just hung the transmission off the bellhousing with no crossmember. The only crossmember used in 60-62's was for automatics, and is very rare. Not too difficult to fab one up though.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
Second generation camaro...perfect fit
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
