Old 09-17-2016, 03:27 AM   #1
Jason7121
Jason7121's Avatar
Tire and wheel size with backspacing
Have a 71 c10 lowered 4/6 that I'm building. It's time to pick wheels and tires out. I like the torque thrust 2 in 18" front and rear. I have stock axle width and stock control arms up front. Does anyone know what back spacing I will need? Want to run a 10" wide or wider in rear and 8" wide up front. Thanks for any advice on fitment.
Jason7121 is offline   Reply With Quote
Old 09-17-2016, 07:40 AM   #2
cruisinthe34
cruisinthe34's Avatar
Re: Tire and wheel size with backspacing
Here's my 71 with 17" front and 18" rear Coy C-5 4.5 B/S front 5" B/S rear. Tire sizes 235/55R17 front, 255/55R18 Rear
Front:
Rear:
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 09-17-2016, 08:33 AM   #3
RodnRudy
RodnRudy's Avatar
I'm looking at the same set up and I'm going to run 5"back space in front and 5 1/2" in the rear
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 09-17-2016, 10:07 AM   #4
Jason7121
Jason7121's Avatar
Nice looking truck. If I wanted to go 10" wide in the rear should I do more back spacing to put wheel further inward?
Old 09-17-2016, 10:49 PM   #5
Mike C
Mike C's Avatar
My '69 has Legend 5 spoke wheels. 235 55 17 in the front on 17x8 4.5" backspace. The rear is 275 55 17 on 17x9 with 5" bs. Both rims are zero offset with those numbers. I'm using a 5 lug axle from a '72.
That's as big a tire that will fit without modifying the inner bed structure on my stepside. Since you didn't specify I assume you have a fleetside. If you go 10" with 6" bs that should work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-17-2016, 11:26 PM   #6
Jason7121
Jason7121's Avatar
Yes fleetside want to use 10" wide rear rim
Old 09-17-2016, 11:44 PM   #7
Mike C
Mike C's Avatar
Tape measure is your friend here. Put a straight edge from the axle wms and meausre to first interference both inside and out. add those together and remove 1" or so from each side. Then you will know what backspace you need as well as how wide a rim you can run. Also, what diameter? It's easier to run a 10" wide 18 than it is a 10" 16 because of the sidewall bulge of the tire. The lower profile larger rim diameter
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-18-2016, 01:31 AM   #8
Jason7121
Jason7121's Avatar
Makes sime I'll measure it out. Thanks for advice appreciate it.
Old 09-18-2016, 01:38 AM   #9
Jason7121
Jason7121's Avatar
So let's say I have 5" from wms to front and 7" from was to Inside of bed and want to run a 10" wide wheel. I would take 5-1=4 and 7-1=6 so I would need 6" back space correct?
Old 09-18-2016, 08:53 AM   #10
Mike C
Mike C's Avatar
That's how I would do that math. But you didn't answer what diameter rim are you looking at. You will require less clearance with a larger diameter rim. Personally, I think 18's are probably the sweet spot for appearance as well as tire availability.
If I was doing mine again I would go 18 instead of 17 but with that said, I wouldn't even consider anything smaller. Or larger for that matter! LOL
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-18-2016, 10:18 AM   #11
cruisinthe34
My rear Rims are 18 x 9.5"
Steve
Old 09-18-2016, 12:51 PM   #12
Jason7121
Jason7121's Avatar
18×10 rear and 18×8 front is what I want to use
Old 09-18-2016, 01:22 PM   #13
Mike C
Mike C's Avatar
Looks that would work fine. 6" bs in the rear on the 10's and 4.5" bs on the front should be GTG.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-18-2016, 10:36 PM   #14
Jason7121
Jason7121's Avatar
Thanks everyone I just ordered torque thrust wheels 20×8 4.5 bs and 20×10 5.75 bs
