![]() Join Date: Mar 2011
Re: 48 Burb, bagged, 5.3, 20 year wait
Whoa, never seen something like that...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#2 | ||||
![]() Join Date: Jul 2012
Me neither Jim.
Our daughter is the same about spiders...catch and release. Wife is more the scream and stomp group. Quote:
That's what we've been wondering. Friends reported it sounded like a grenade going off at a steady cruise speed. Fairly high speed though. The rear was just rebuilt with new gears, diff case, bearings by a guy who specializes in rear ends in WI. I expected something like the pinion shaft bolt broke and ran between the pinion and ring gear. Or a diff bearing cap came loose, or loose pinion nut. None of the typical contributers were noted. Another friend with a long and strong auto service engineering background is theorizing the drive shaft (newly manufactured) failed at high speed. The length and weight caused it to begin whipping, contacting the ground leading to the failure. Driveshaft jammed to the ground, prying the pinion up and back, leading to the housing failure. He advised if the rear locked first, the driveshaft would have twisted rather than bent. He might have a point. There are three fresh gouges in the road evident before the oil was spread over the surface. So, possible he is right...he makes a compelling case. |
#3 | |
Ephesians 2:8
Best of luck to your buddy, that is a killer wagon, I've always liked it.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
That theory makes sense. Was there any other damage to the car? Glad they got pulled over safely.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#5 | ||||
Yeah, the car seemed angry with the road for sure. Hope you finished the install on your transmission ok! Quote:
Here the rear cover is holding the axle tube in. |
Note the negative camber on left rear wheel.
