Old 09-17-2016, 10:54 PM   #651
GAc10boy
GAc10boy's Avatar
Re: Knomadd '71 SWB C-10
Now that's good progress!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 09-20-2016, 06:50 PM   #652
knomadd
knomadd's Avatar
Thanks! It's a little slower than I'd like, but I'll get it done soon enough.
I have the VHX gauges installed into the bezel.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-20-2016, 09:31 PM   #653
Blown06
Blown06's Avatar
Man I just got caught up your progress, everything is looking nice. I'll have to stay up this one.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 09-20-2016, 10:37 PM   #654
Advanced Design
Advanced Design's Avatar
Love those gauges...DD VHX are a real nice set up.
Advanced Design is offline   Reply With Quote
Old 09-20-2016, 10:48 PM   #655
rincones
rincones's Avatar
Nice.
I will go by your house this weekend.
Rincon
rincones is offline   Reply With Quote
Old 09-21-2016, 10:48 PM   #656
knomadd
knomadd's Avatar
Tonight I was able to get the a/c unit out, plate off the firewall and some more wires out of the way.
-Duane
Old 09-22-2016, 10:16 AM   #657
knomadd
knomadd's Avatar
Thanks Jarrod! I hope the slow pace isn't too boring.
Thanks Doug, I'm excited to see them up and running!
Originally Posted by rincones View Post
Nice.
Thanks Mike! We've got some things going on this weekend, so if the garage door isn't open, I'm probably not home. I'm hoping to get more done while I am home though, so stop by if you catch me outside.
-Duane
Old 09-23-2016, 08:25 AM   #658
Bennett68C10
Bennett68C10's Avatar
Nice Gauges!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-25-2016, 11:46 AM   #659
NewType72
NewType72's Avatar
Gotta love all the new part pictures! LS is looking like a beast!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-25-2016, 07:45 PM   #660
aboesec10
aboesec10's Avatar
updates??????????????????????????? lol
c10clubtexas
aboesec10 is offline   Reply With Quote
Old 09-26-2016, 12:26 PM   #661
knomadd
knomadd's Avatar
Originally Posted by Bennett68C10 View Post
Nice Gauges!
Thanks Keith!
Thanks Dylan, it's coming along nicely.
Aaron, you've been updated more than anyone else. But yes, here's some from the weekend...
Here's the floor I started with...
Here's what I currently have...
And what I will end up with...
Still need to get the holes drilled and probably use something like riv-nuts to install it. Wondering what I should use for the sealant between the panels to keep the elements out. Maybe seam sealer on the bottom side?
I also mounted up the Dirty Dingo LS low mount A/C bracket for the Sanden SD7 compressor. It fits pretty well.
I test fit the motor (sorry no pics) and it was close. I'll have to move the engine stands back to the rear holes on the frame. I have the motor mounts as far forward as I can on the plates and the oil pan sits on top of the steering center-link. There's enough room from the firewall to the back of the heads to move another 2-3" comfortably, so I think it's the best option. Plus, the trans was sitting on the cross member (which I hadn't moved yet) so it was up too high, causing the front to sit low. All said and done, I at least know what I need to do now to make it fit, so that's good news.
-Duane
Old 09-26-2016, 12:31 PM   #662
Hart_Rod
Hart_Rod's Avatar
I put Fatmat on my high hump, bolted it in. I then took strips of the Fatmat and put over the bolts and edge of the high hump sealing it to the floor. It created a good seal and shouldn't be that hard to remove if the need every arises. Hope that makes sense.
Hart_Rod is offline   Reply With Quote
Old 09-26-2016, 12:48 PM   #663
knomadd
knomadd's Avatar
Thanks Rob, it does make sense. I still have some of the eastwood mat I used everywhere else on the floor. I thought about using it and I will on the high hump itself, but I'm more worried about the dirt and moisture collecting between the high hump and the floor from under the truck. I don't want to cause rust to form by not attempting to seal it. I hope that makes sense.
-Duane
Old 09-26-2016, 01:35 PM   #664
gringoloco
A guy with a truck
gringoloco's Avatar
There was sealant applied there at the factory. Wouldn't hurt to run a bead
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 09-26-2016, 02:50 PM   #665
MMcMasters
MMcMasters's Avatar
Very sharp!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 09-27-2016, 05:47 PM   #666
knomadd
knomadd's Avatar
Awesome, thanks Chris!
Originally Posted by MMcMasters View Post
Very sharp!!
Thanks!
Not much to post, but something for my records I guess. I removed the engine stands after work yesterday to put them in the rear 6 cylinder position and decided to clean up all the muck while I was at it. Turns out there wasn't much paint left under the 40+ years of gunk. I then painted it with some rattle can satin black.
There's still some crap in front of the cross member that will need to be cleaned up, as well as the frame rails, but this was the extent of what I got done. I'll need to clean the frame rails and put a coat of paint on before I re-mount the engine stands. Hopefully that's tonight's progress.
-Duane
Old 09-27-2016, 07:54 PM   #667
gringoloco
A guy with a truck
gringoloco's Avatar
Looks much better! That lip on the front of the crossmember traps all kinds of filth
-Chris
Old 09-27-2016, 09:09 PM   #668
NewType72
NewType72's Avatar
I absolutely despise that front crossmember lip!! The hatred I have for it is immense lmao
- Dylan
(209)-985-7721
Old 09-28-2016, 10:41 PM   #669
knomadd
knomadd's Avatar
Yep, it was a pain to clean. Not my favorite thing to do.
Here is last nights progress...
And tonight, I cleaned and painted the engine stands and new power steering pump so it won't rust. Not too exciting to look at so I didn't take a pic of that.
-Duane
Old 09-29-2016, 01:06 AM   #670
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
I always use the foam weatherstripping on the flange of the high humps to seal them up..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-29-2016, 09:11 AM   #671
knomadd
knomadd's Avatar
Where do you get that from? I'm sure the hardware store stuff isn't quite the same, right?
-Duane
Old 10-03-2016, 10:43 AM   #672
knomadd
knomadd's Avatar
Well, I got the engine set in this weekend. It only took 4 tries to get the mounts right.
-Duane
Old 10-03-2016, 10:49 AM   #673
Hart_Rod
Hart_Rod's Avatar
Look at your local auto parts store, they usually sell some stick on weather seals.
Coming along nicely!
Old 10-03-2016, 11:20 AM   #674
mcbassin
Still Learning
mcbassin's Avatar
Looking good Duane! Keep up the good work.
Old 10-03-2016, 06:57 PM   #675
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks awesome!
Ryan
1969 Chevy milk truck
