Old 09-18-2016, 11:27 PM   #1
Nima
Blue 67
Chevy engine wt. comparison
Hi:
How much does a SBC 350 weighs in comparison with a 5.3 (LM4 I guess) and 6.0 (LQ4)? How these wt. changes can affect the front suspension/steering and overall performance?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 09-19-2016, 08:06 AM   #2
DjS71
Re: Chevy engine wt. comparison
Quick search says BBC 665, SBC roughly 575lbs, Iron block (LQ4) Gen III+ roughly 520lbs, Aluminum block (LM4) Gen III+ subtract 75lbs or so.
The trucks are front heavy on account of the bed just being a sheet metal open top box and the windshield, battery and motor/trans forward of the center of the truck.
As to how better weight distribution actually affects the vehicle I don't have any more google time. Visually i'd imagine it would affect ride height.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 09-19-2016, 08:47 AM   #3
68Stepbed
68Stepbed's Avatar
I don't have the paperwork in front of me, so my numbers may be slightly off, but I know their close. A few years ago, I weighed my truck on a four corner scale at a RideTech booth at a show. At the time, it had a 350/TH350 mounted in the factory V8 (forward) location. Later that summer, I blew that engine and swapped in the LS1/700R4. The engine is mounted in the 6 cyl(rearward) location along with offset adapter plates.
With the 350 combo:
3737 lbs and almost right at a 60/40 weight bias.
With the LS1:
3590 lbs and about a 55/45 weight bias.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-19-2016, 12:05 PM   #4
davepl
davepl's Avatar
I started with an iron-headed 396.
Installed aluminum heads, intake, headers - nose came up 1/2"
Replaced iron 396 with aluminum 376 (LS3) - nose came up 1/2"
Now for some reason either I got weirdly used to it or it settled, because I was going to swap springs down to small block springs but the ride height is fine. I guess my point is that swapping to a much lighter motor will change your ride height and alignment.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-20-2016, 11:46 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
Sbc to 5.3 swap. I also moved the engine back and relocated the gas tank under the bed. It handles much better.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
