Old 08-22-2016, 08:33 AM   #1176
Bennett68C10
Bennett68C10's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by gringoloco View Post
...but if I'm gonna go to all the trouble, why not go all the way...
been there twice now, at least on my current build I decided to go all the way from the start.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-22-2016, 09:38 AM   #1177
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks killer man
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-14-2016, 10:13 AM   #1178
gringoloco
A guy with a truck
gringoloco's Avatar
Well, after a bunch of hemming and hawing, the suspension decision has been made. I sold the SV1000 this past weekend and put the money toward a PB touring front and NL coilover rear (with some minor personal tweaks--great vendors both!). Planning on using the Ridetech single adjustable "HQ" series on all four corners.
This plan will put me at (or near) my current ride height, but with hopefully improved steering, handling, and ride quality. It should also leave room to adjust down approximately another inch, if I decide later that I want to be lower ...and I can always do a PB body drop if I just gotta have that extra .75". For now, we'll see just how easy of a "bolt-on" these will be
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-14-2016, 06:07 PM   #1179
Looking forward to your work on that ole pickemup.
Old 09-19-2016, 02:17 PM   #1180
gringoloco
A guy with a truck
gringoloco's Avatar
Blazer is getting some attention while I wait for parts, which, thanks to shores6 are already beginning to show up
-Chris
Old 09-19-2016, 04:06 PM   #1181
mcbassin
Still Learning
mcbassin's Avatar
Very nice!
Old 09-19-2016, 08:32 PM   #1182
gringoloco
A guy with a truck
gringoloco's Avatar
...and some unexpected NL boxes:
-Chris
Old 09-20-2016, 05:20 PM   #1183
Gus350
68 C 10
Gus350's Avatar
Very nice truck I love this build. When you changed to the longer Dorman wheel studs did you end up having to use a longer or deeper lug nut. Thanks.
I'm in the same boat with my Boss 338 and rear disc I'm getting about 5-6 turns to tite.
Thanks Kevin
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 09-20-2016, 05:59 PM   #1184
shores6
shores6's Avatar
Can't wait to see the new setup!
Todd
https://www.instagram.com/shores6/
Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419
shores6 is offline   Reply With Quote
Old 09-21-2016, 01:47 AM   #1185
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Kevin
Thanks! Same lug nuts, though I did have to enlarge the holes in the axle to fit the studs.
Me too! All of the NoLimit stuff is here already--received the rear coilovers today. Now just waiting on the PB crossmember and arms. Still need to figure out what rack I want to use. I've been advised that the quick ratio (2.5 turns) is too twitchy with the dropmember. Dave suggests using the standard 3.0 turns version, which was offered on 4-cylinder Mustangs. I've got an idea to use the 03-04 Cobra rack, as it's basically the pinnacle of the Mustang II/Fox rack design, with tight, crisp feel, but I definitely don't want the twitchiness.
-Chris
Old 09-21-2016, 08:11 AM   #1186
mcbassin
Still Learning
mcbassin's Avatar
I'm going to follow this upgrade closely. It sounds very similar to what I "think" I may want to do to my truck. I would love to do these exact upgrades to my truck.
Old 09-21-2016, 08:38 AM   #1187
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by mcbassin View Post
I'm going to follow this upgrade closely. It sound very similar to what I "think" I may want to do to my truck. I would love to do these exact upgrades to my truck.
I don't mind being the guinea pig--hopefully it turns out like I have it in my brain. Overall, the cost is comparable to buying a full Hotchkis setup, with the benefit of height adjustability (to a degree). Adjustable shocks, tube arms, and rack could be considered upgrades above what the Hotchkis kit offers.
Ideally, this is a bolt-in affair, with little 'custom' work required. For me, I know going in I'll have to do some exhaust work to get around the new panhard and I may end up shortening my steering column (not required, personal preference). Unknown possibles include driveshaft, H-pipe, cooling fan, high-hump, and pretty much everything else.
-Chris
Old 09-27-2016, 07:56 PM   #1188
gringoloco
A guy with a truck
gringoloco's Avatar
Boxes are piling up
-Chris
Old 09-27-2016, 09:08 PM   #1189
NewType72
NewType72's Avatar
Oooooooohhh me likey boxes!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-27-2016, 09:59 PM   #1190
Rochlow
Ohhhh hheeeyy!! Tuning in! You got my attention again!
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 09-28-2016, 07:38 PM   #1191
gringoloco
A guy with a truck
gringoloco's Avatar
Pretty excited here, too! Unfortunately, it's gonna have to wait until the Blazer is back together, as the bed currently looks like this:
-Chris
Old 10-02-2016, 09:08 PM   #1192
gringoloco
A guy with a truck
gringoloco's Avatar
I am in love with the stance of this truck:
Love can be a dangerous (and wonderful and expensive) thing...
-Chris
Old 10-02-2016, 09:10 PM   #1193
Love is a dangerous thing...
Yep
Old 10-02-2016, 09:39 PM   #1194
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
That truck is Bad A$$, any info on it?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 10-03-2016, 12:40 AM   #1195
gringoloco
A guy with a truck
gringoloco's Avatar
Check out @terry_14_rose on IG. Pretty sure it debuted at Columbus GG and has been making the rounds. Built by strangemotion in TN.
-Chris
Old 10-05-2016, 12:54 PM   #1196
crazycrew
WOW!!! Just read this entire thread. Amazing job on this truck. Hopefully I can build one almost like it when I find one!!
Brooks -- South Louisiana
2004 Tahoe, DD
Currently on the prowl for that right C10 project
https://www.facebook.com/brooks.landry.1
IG : brolandry
crazycrew is offline   Reply With Quote
Old 10-05-2016, 04:09 PM   #1197
mcbassin
Still Learning
mcbassin's Avatar
I love the stance of this truck too! I looked it over closely at GG in Fort Worth. Very very nice! Everything is so clean too.
Old 10-05-2016, 07:47 PM   #1198
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for taking the time! Nice trucks are out there, keep looking. I waited a long time to get mine--always wanted one. I've had this one now almost 12 years and it has changed a lot in that time. Not done yet, stay tuned!
It looks to be really well done--very simple and sanitary. I'm not a big fan of the ducktail, but to each his own...
Stance-wise, I just confirmed order of a level 2, version 7, coilover DM (instead of the mild I was originally planning on), which should get me adjustable between 6 and 7" under the front cab mount (I'm at about 7.5" now)
-Chris
Old 10-06-2016, 05:46 PM   #1199
gringoloco
A guy with a truck
gringoloco's Avatar
That Dave Porter sure knows how to get my pulse racing...
-Chris
Old 10-06-2016, 06:11 PM   #1200
lolife99
67-72 parts collector,…
lolife99's Avatar
Follow @tre5customs on Instagram. He's building a 67-72 Porterbuilt coil over truck for a customer. He's pretty good about posting lots of pics.
Keith
Convert to disc brakes.
