02-17-2015, 01:59 PM | #1 |
High Note Horn Mounting Location ?
Found a dual horn set up at the local wrecking yard with jumper wire. When I went to mount the high note horn I noticed my core support was not drilled to accept the second horn ? The indentation is there to locate it, is this normal ? Thanks for any help.....
71 C-20 07 Magnum RT AWD |
02-17-2015, 02:21 PM | #2 | |
Re: High Note Horn Mounting Location ?
02-17-2015, 02:25 PM | #3 |
Here's where it goes.
02-17-2015, 03:10 PM | #4 |
02-17-2015, 04:01 PM | #5 |
all the 71-72
's I had the dual horns all mounted with a single bolt thru the mount on the core support// that picture posted is not roght for a factory mount
02-17-2015, 04:36 PM | #6 |
Hmm... that's interesting. I've looked at dozens of these trucks with dual horns and they all had the high note horn located in that location under the left headlight as shown in the picture I posted. Do you, or does anyone else, have a picture showing one in the location you are referring to? The low note horn is the one on the core support adjacent to the radiator which I am positive is its correct location.
02-17-2015, 07:23 PM | #7 |
Agree with location but I don't know which horn goes where.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-17-2015, 07:54 PM | #8 |
That is where they are located on my 72 cheyenne super.
02-17-2015, 08:21 PM | #9 |
So...the $10,000 question is:
has anyone mounted a low/high note horn pair on an earlier truck that doesn't have the factory mounting holes? |
02-17-2015, 08:32 PM | #10 |
The high note horn goes under the headlight. The low note goes on the vertical "support" next to the radiator. This is the same location as the mounting point for low note only trucks.
I mounted a high horn on my original core support in the late 70s by drilling a hole in about the same location as shown in the picture I posted. I based that on the location on the donor vehicle. The tough part is finding a high horn that works. |
02-17-2015, 08:32 PM | #11 |
Moderator
Easy, just bolt them to the same location, one turned 90 degrees from the other and stack them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-17-2015, 08:54 PM | #12 |
Old member
My horns that I took off my 71 both have the same mount and both where under the light! Unless you are showing the truck in a 100% state why even worry about it. Just mount them and be happy!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-18-2015, 12:19 PM | #13 |
I removed the dual set up from a 69 C-20, they where mounted side by side, not using only one bolt. My 71 GMC has the locater notch for the second horn but no hole ? Also the jumper wire is way to short to connect that horn under the light ?
02-18-2015, 01:57 PM | #14 |
The picture in post 1 of this thread is the best I can find of an original jumper wire.
http://67-72chevytrucks.com/vboard/s...d.php?t=497821 |
09-24-2016, 12:59 PM | #15 |
good info
