Never Ending Projects
Re: Budget air bag setup?
Because of air transfer between the bags when you corner. When one side compresses, the air gets moved into the other side bag and cause it to lift, creating even more body roll. I did figure out a way to do it with one fill port and one exhaust port but you need to run 4 check valves so air can only travel one way in the system. If you want basic, run an individual valve to each bag.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
| Bookmarks |
| Tags |
| air, airride, bagged, bags, schrader |
