Old 09-18-2016, 10:43 PM   #1
mike1954
power steering pump bracket
I have a1956 chevy 3100 350 sbc, long water pump, cast iron exhaust manifolds, vortec heads. I am using front motor mounts. Is there any factory or after market power steering pump brackets that will clear the motor mounts?
mike1954 is offline   Reply With Quote
Old 09-20-2016, 02:08 PM   #2
OrrieG
OrrieG's Avatar
Re: power steering pump bracket
I have the same, here is what I fabricated. Note it uses the long water pump with the cast bracket hole. I also made my AC and Alternator brackets matching up the pulleys was a PITA, you cannot mix and match two and three groove lowers with uppers, they come as matched sets.
Old 09-20-2016, 07:31 PM   #3
Russell Ashley
Russell Ashley's Avatar
I used a p/s pump mount off of a 1980 Chevy truck with 350 engine. Be sure to get the part off of the exhaust manifold that the locking bolt threads into. I'm using a long water pump and I suggest that you get all of the pulleys off of the engine that you get the mount from. The pump wouldn't swing down far enough until I ground a notch out of the left side engine mount bracket, but you don't have to remove enough material from the bracket to weaken it.
Russell Ashley is offline   Reply With Quote
Old 09-26-2016, 09:33 PM   #4
mike1954
Thanks for the ideas
