Sources for Burb & CC 2nd Door trim
Is there an aftermarket source of panels & trim for the rear doors of a 77-80 suburban or crew cab? I was surprised that the big vendors only sell front door stuff, but my memory tells me I've seen at least the trim rings (if not the inserts) somewhere in the past. Can't find anything now, though.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 Last edited by SilverMiner; 09-26-2016 at 02:35 PM. |
Re: Sources for Burb & CC 2nd Door trim
Well, shoot. Guess I'll hit the local pick-n-pulls, ebay, etc.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
Ebay is going to be the best bet. Not much stuff out there for the rear doors
If you can find stuff for the rear doors, it will usually have to be through C-list, e-bay, swap meet, or classifieds (I found a pair for my dually in the classifieds here).
I do know that the available aftermarket front door trim (specifically from LMC) is not an exact match to the OE pieces for the rear door if you do find some. It was very noticeable to me & my buddy w/steered me to find a creative solution around the issue.
