Old 09-25-2016, 08:03 PM   #1
billetproofcustoms
billetproofcustoms's Avatar
1966 283 stock compression??
guys,
I am trying to decide if my bone stock 66' 283 needs to be rebuilt or not, it is currently on an engine stand, my question is this: what compression reading should I be getting on my gauge? I am rotating it by hand.
would it be worth putting the starter back on it and rigging it up to use for rotating the motor?
billetproofcustoms is offline   Reply With Quote
Old 09-25-2016, 08:07 PM   #2
PGSigns
PGSigns's Avatar
Re: 1966 283 stock compression??
By hand will be way to slow. You can do a leak down test on the stand. Will give you good info in the condition.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-27-2016, 12:19 PM   #3
billetproofcustoms
can no one tell me what i should be seeing for compression on a stock 283 ??
Old 09-27-2016, 01:13 PM   #4
andyh1956
With carb butterflies open at cranking speed a fresh 283 outta show you around 150 psi. P.P. heads may be 5-10 psi higher.
andyh1956 is offline   Reply With Quote
Old 09-27-2016, 02:06 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Around 140-150.
Old 09-27-2016, 03:36 PM   #6
andyh1956
Yeah my 283 had true flat tops w/ only two valve reliefs in them & shim gaskets.
