Old 03-20-2004, 02:07 AM   #1
MAC67
" SHOW ME"
MAC67's Avatar
Question ok wheres the ole timers , what is it ? how does it work ? how old ?
hi guys i was diggin through some old car parts and came across this , ive got a pretty good idea what it does , im not going to put it on anything , i was wondering , how old is it roughly , value ? and just how they were hooked up , it is a Marvel Mystery Oil oiler for top cylinder , did it hook to the carb and slowly deliver marvel oil to the fuel ? it says to adjust for 1 qt every 1000 miles , it is in really good shape , still has a litle oil in it , jar isnt cracked anywhere and everithing seems to be in great working order , the little spring door works great , and the brass adjust ment is very very free , but not loose , so hit me wiht it guys , whats it all about , did you ever run one ? ive seen similiar setups ran before but not one quite like this .
MAC67 is offline   Reply With Quote
Old 03-20-2004, 02:09 AM   #2
MAC67
" SHOW ME"
MAC67's Avatar
top
Old 03-20-2004, 02:10 AM   #3
MAC67
" SHOW ME"
MAC67's Avatar
brass adjustment
Old 03-20-2004, 02:11 AM   #4
MAC67
" SHOW ME"
MAC67's Avatar
label
Old 03-20-2004, 02:12 AM   #5
MAC67
" SHOW ME"
MAC67's Avatar
spring hinged door , it says , run motor while adding , or something along those lines
Old 03-20-2004, 03:30 AM   #6
ZOOMY
MM Oiler
Marvel oilers were popular years ago; (50's). I've seen alot of them on Merc flatheads. I still use Marvel in some of my older engines.
ZOOMY is offline   Reply With Quote
Old 03-20-2004, 04:05 AM   #7
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
Can't really say how that device works, but you can still buy Marvel Mystery Oil. We used to use it as after-run oil for our R/C airplane engines...it's good stuff, great for loosening up things that are gummed up or stuck. It smells good, too!
Stepsides 4Ever is offline   Reply With Quote
Old 03-20-2004, 08:08 AM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
I can honestly say I am not old enough to have been around when that was used. From the looks of it, it is hooked up to a vacuum sorce on the carb. As the engine runs it would suck a small amount of oil out(1 quart/1000 miles) to lube the top cylinders and valve train. The screw at the top would control the orifice size and how much oil could be pulled out per mile.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-20-2004, 10:30 AM   #9
cdowns
cdowns's Avatar
DA-BURB'S got the right idea,was a pretty common accessory to find on ford flathead engines and model a&t's also . i remember seein them in the jcwhitney cat when i was a kid
Old 03-20-2004, 11:35 AM   #10
junkyardjohn
junkyardjohn's Avatar
YEP .... I'M A PACKRAT. I HAVE TWO BRAND NEW INSTALLATION KITS. (WHO KNOWS WHAT FOR??) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-20-2004, 11:36 AM   #11
junkyardjohn
#2
junkyardjohn
DON'T RENT U-HAUL
Old 03-20-2004, 11:37 AM   #12
junkyardjohn
#3
junkyardjohn
DON'T RENT U-HAUL
Old 03-20-2004, 04:28 PM   #13
70cst
70cst's Avatar
If I remember right...this was use to oil the muffler bearings?
HeHeHe
70cst is offline   Reply With Quote
Old 03-21-2004, 02:10 AM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Used to see the same setup for water injection to help cool the intake charge.I don't know whether it worked or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-21-2004, 02:32 AM   #15
stllookn
Saving 1 truck at a time!
stllookn's Avatar
It looks like a common gravity feed oiler which was standard on most rotating machinery before pressure oil systems and sealed bearings were perfected.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-21-2004, 02:39 AM   #16
Stepsides 4Ever
Water injection works, and works well...but the maintenance involved with keeping the system free of scale and corrosion, as well as filling up with gasoline and water simultaneously, proved to be intolerable for most people. In other words, the pain outweighed the gain...
