Closed Thread
Old 09-25-2016, 03:32 PM   #4401
kilrcady
Re: What did you do to your truck today? Chapter II
Hey jrainman,Are you a tinknocker?
kilrcady is offline
Old 09-25-2016, 07:04 PM   #4402
jescates
jescates's Avatar
Removed an alarm system that was installed and fixed some hacked wires! Talk about a P.I.T.A. Finding wires dangling and not going anywhere! The good thing is it starts and all lights work.
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline
Old 09-25-2016, 07:38 PM   #4403
everettelane
everettelane's Avatar
Went to the Humble swap meet this morning, found some leather seats for my truck just have to make some brackets.
everettelane is offline
Old 09-26-2016, 09:32 PM   #4404
In The Ten Ring
I picked up my epoxy primed original fender and dropped it off with the painter.
In The Ten Ring is offline
Old 09-26-2016, 10:32 PM   #4405
hugger6933
I cut out the back glass, inner rocker and A and B pillars. I also trimmed up the replacements, laid in the inner rocker/ floor piece and screwed it down so I can cut out the off stuff.I also fitted up the outer rocker and clamped it down. I got along pretty good on it today. Hopefully tomorrow I can get a good bit of it welded up. Once I get both sides in I'll put it on the flipper dolly and do the cosmetics for the floor and rockers. Of course sale day is Wed so I may have to quit on it again. Normally when I get my old truck in the shop to work on it I get a transport load of wrecks soon after.
hugger6933 is offline
Old 09-26-2016, 10:45 PM   #4406
cornerstone
cornerstone's Avatar
I built my transmission crossmember.
cornerstone is offline
Old 09-26-2016, 10:52 PM   #4407
everettelane
I got started building my new seat brackets, there just isn't enough time in a day especially when you don't get home till after 6 O'Clock.
Old 09-26-2016, 11:11 PM   #4408
cornerstone
And I got started on strengthening my front crossmember in order to fit the new gen 5 lt 😀. In this photo I'm using cardboard to get the shapes I need to cut out of plate steel.
Old 09-26-2016, 11:17 PM   #4409
Howitzer
Got rid of my Eddy 750 CFM on my 402 and put in a Quick Fuel 680 with Vacuum Secondaries and put it on the dyno.
Love this carb! Blows the doors off the Edelbrock.
Howitzer is offline
Old 09-27-2016, 08:10 PM   #4410
Towbiz
Stripped down my newly acquired Buddy seat , sending frame out to powder coating & researching new foam & upholstery kit . Removed grill to have it polished .
Towbiz is offline
Old 09-27-2016, 08:17 PM   #4411
In The Ten Ring
I received my new KKS radiator today. I inspected it out of the box and it looks very nice.
I'll try and test fit it into the core support tomorrow.
Old 09-28-2016, 12:35 AM   #4412
OregonNed
OregonNed's Avatar
I went from a 12 inch oval air cleaner to a 14 inch round, 3 inch high... I like having more of the carburetor covered, and the smaller one looked a little too small.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 09-28-2016, 08:50 AM   #4413
matthamby
Where did you get the adjusting alternator arm/bracket? It just looks cooler than the factory style bracket.
matthamby is offline
Old 09-28-2016, 10:26 AM   #4414
OregonNed
OregonNed's Avatar
If I remember right - from summit - along with the triangular shaped mount on the bottom. Agreed - wasn't thrilled with the black bracket covering the top. The alternator was a replacement (Power Master) because the other was faulty when I purchased the truck. The brand was March, I believe.
Old 09-28-2016, 11:02 AM   #4415
matthamby
Thanks! I found the March ones, Summit also had their own, much cheaper, I wonder how the quality is?
Old 09-28-2016, 07:35 PM   #4416
sKnNyPpY
sKnNyPpY's Avatar
Got my Trim Parts black carpet in and new sill plates...nice fit, just needed to trim the back by the tank.
Name:  Carpet Three UP.jpg
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 09-28-2016, 09:27 PM   #4417
Bone Stock
I sought new wheel cylinders- the three letter company sent ill-fitting versions... Nobody believes that I have leafs on my 67 127" 3/4 T 2wd BB V6 305.
Thanks,
Kevin
'67 GMC C2500 305 V6 Power Nothing
Bone Stock is offline
Old 09-28-2016, 09:28 PM   #4418
Bone Stock
Sweet look and a quick cleanup. Nice!
Thanks,
Kevin
Old 09-28-2016, 09:47 PM   #4419
custom10nut
custom10nut's Avatar
What brand name are your valve covers, and breather lid? They look great! I wonder if the valve overs come in a tall version? I have roller rockers and standard ones won't clear.
Beautiful engine bay.
custom10nut is online now
Old 09-30-2016, 10:49 AM   #4420
tbrogdon
I installed my new HID lights with halo's.
tbrogdon is offline
Old 09-30-2016, 10:58 AM   #4421
matthamby
those look great! where did you get them, what brand, how much?
Old 09-30-2016, 12:12 PM   #4422
tbrogdon
Thank you, I picked them up from Octane Lighting for $218 shipped.
tbrogdon is offline
Old 09-30-2016, 03:29 PM   #4423
OregonNed
OregonNed's Avatar
I bought them at the Portland swap meet one spring. Unfortunately, I do not know the brand, but I see so many on Ebay as nostalgia style? That is also where I found the air cleaner. I just did a seach on Ebay for finned valve covers and air cleaner and found several. There was also a set on the first page advertised as tall. Thank you!
Old 09-30-2016, 03:33 PM   #4424
OregonNed
OregonNed's Avatar
Last night I added a new turn signal lever.
Old 10-01-2016, 07:12 PM   #4425
In The Ten Ring
I worked on the truck all day! Intense effort.
I put my locking gas cap back on, picked up a quart of POR 15 substitute (forgot the name of it), and ran that over to the painter.
Closed Thread
