Old 05-09-2016, 01:47 PM   #1
blown240
blown240's Avatar
Air Shocks For a 61
I want to get some air shocks for my 61 Panel. I will only use them occasionally for load capacity.
I found Monroe part number MA757 that is the right length, and has the right bolt diameters from what I can see, but the upper and lower mounts are about 1.4 too wide.
Is there a part number that will work? The truck is lowered a but, but not so much that a stock length shock won't work.
Thanks!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 05-09-2016, 05:11 PM   #2
blown240
blown240's Avatar
Re: Air Shocks For a 61
The Truck-shop shows the same rear shocks from 60-72. Is that correct?
If so, I can use the Monroe Max-Air - Part # MA727. But that shows Extended Length: 20-3/8",
Compressed Length: 12-3/4". Seems like the stock shocks are longer than that...
Rockauto shows stock rear shocks are 25.5" open and about 15" closed...
Old 05-13-2016, 11:53 AM   #3
blown240
blown240's Avatar
Ok guys. I thought I would let you know what I ended up getting in case anyone else is interested in this.
Monroe MA743. They are for 73 to 86 Chevy Trucks. I had cut down the mounting sleeves and bushings because they were about 1/4 inch too wide, and I had to make a steel sleeve to put thru the bushings because the hole was too big. But all in all it took about 30 mins, and they seem to fit great!
Old 05-14-2016, 12:21 AM   #4
Captainfab
60-66 Nut
Thanks for the follow up with a part number.
Old 05-14-2016, 05:50 AM   #5
notsolo
notsolo's Avatar
Thanks for sharing...Are these mounted in the stock location? Let us know how they handle with a little weight in the back.
notsolo is offline   Reply With Quote
Old 05-14-2016, 12:17 PM   #6
blown240
blown240's Avatar
Yes they are n the stock location. I will report back once I use them for a load....
Old 05-14-2016, 05:23 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, thanks for posting back.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-19-2016, 08:36 AM   #8
K98AL
K98AL's Avatar
Have you loaded that truck up yet? I'm looking at doing the same thing to my '62 - when I hook on to a 16 foot trailer with my Allis CA on it, the rear bumper is really low.
Just wondering how much load those Monroes will handle.
K98AL is offline   Reply With Quote
Old 08-19-2016, 08:46 AM   #9
LostMy65
LostMy65's Avatar
Keep in mind; air shocks put the load on the shock brackets. Not the way they were intended.
Personally, I'd skip the air shocks, and just replace the trailing arm springs with air bags.
Old 08-19-2016, 11:39 AM   #10
blown240
blown240's Avatar
I agree with Lostmy65. While these shocks do help carrying a load, if your towing, I would do bags.
Thats being said, I have loaded the truck up pretty good, and the air shocks do help, but not at all like bags.
Old 08-19-2016, 12:14 PM   #11
K98AL
K98AL's Avatar
^^^that's what I was afraid of. Anyone make a bag for a '62 that doesn't involve major reconstruction?
Old 08-19-2016, 12:20 PM   #12
LVPhotos
LVPhotos's Avatar
I got mine from Ride Tech with Schrader valves and prefab cups
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-19-2016, 12:24 PM   #13
LVPhotos
LVPhotos's Avatar
Bolts right in.
Old 08-19-2016, 12:50 PM   #14
jtrichard
LV you have a part # for us THANKS
jtrichard is offline   Reply With Quote
Old 08-19-2016, 02:06 PM   #15
LVPhotos
LVPhotos's Avatar
1963-1972 Chevy C10 - CoolRide Rear System
Part #: 11334099
http://www.ridetech.com/store/1963-1...ar-system.html
Old 09-29-2016, 12:46 PM   #16
blown240
blown240's Avatar
I thought I would report back on my air shocks.
I had the biggest load I've had in a while. Roughly 600 pounds of concrete, all of it sitting behind the rear axle. With 100 psi in the air shocks, I was about 1" off the bumpstops. This is with 3" truck lowering springs, which brought the panel down about 5".
I took it easy getting home, but it wasn't bad really...
Old 09-29-2016, 02:07 PM   #17
DLW
Nice.
I agree about heavy loads and air bags being much better.
I also use air shocks on another vehicle (my C10 has bags) just to keep same ride height with small loads since I am lowered a bit and don't want to sit on the bump stops. I doubt I ever go more than 500 lbs and the air shocks do a great job for light duty stuff. Run min pressure at 25-30 psi with no load and around 100-120 psi with 500 lbs.
DLW is offline   Reply With Quote
