Truck bed help?
How can I tell if this is the bed that came with my truck it's a 1970 gmc with side marker lights on the front but not the bed didn't all trucks have side lights since 1969 might b wrong any help plz trying to do d out if I have a 1967 short bed
The Older Generation
Re: Truck bed help?
Either someone has filled the marker light holes or it is a '67 bed. You should be able to see from underneath if someone has filled them.... LockDoc
Re: Truck bed help?
Doesn't shortening the bed also make the rear marker lights go bye-bye? Maybe it's a shortened long bed?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Re: Truck bed help?
Depending on how you shorten it. But then you also have the middle stake pocket to make disappear, so the OP can look for signs of that too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
![]() Join Date: Feb 2009
Re: Truck bed help?
If the rear wheel well rim is the same front and back then it's a short bed. If the front rim curves forward at the bottom then it's a long bed. Not sure if that applies to all years 67-72.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
