Old 09-28-2016, 10:43 PM   #1
jlipman
Longer brake hoses
Where can I get longer brake hoses for the front discs. The front of my truck is bagged and they are too short for comfort.
jlipman is offline   Reply With Quote
Old 09-28-2016, 11:22 PM   #2
1bad396ss
Re: Longer brake hoses
I had SS braided hoses made to my measurements with the ends set up the way I needed from a place called Brake Hoses Unlimited. Great service as well. I believe www.brakehoses.biz will get you there.
1bad396ss is offline   Reply With Quote
Old 09-29-2016, 12:51 AM   #3
Rod Run
Rod Run's Avatar
I got ones from an early second gen Camaro and they were longer, I just don't remember how much, but I have a 5" drop and no problem
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 09-29-2016, 07:28 AM   #4
cdowns
cdowns's Avatar
speedway has different length hoses in it's catalgue
Old 09-29-2016, 07:37 AM   #5
MoFormula
I have used BHU as well and was very happy. I just added 2" to the standard length and they shipped.
MoFormula is offline   Reply With Quote
Old 09-29-2016, 12:35 PM   #6
bs46488
I searched for an OEM solution when my stock replacement lines were too short.
I think the stock lines are 12.25". I found lines for a 1974 Caprice that had the right threads and banjo that are 15.25". I have them on my truck now, but would say they are about 1" too long because they make contact with the spindle.
bs46488 is offline   Reply With Quote
Old 09-30-2016, 05:58 PM   #7
merlin3
i used 3/4 ton front brake hoses from GMC Pauls, worked out fine.
merlin3 is offline   Reply With Quote
