I'm looking for the Parking Brake spring that connects between the end of the front cable adjustment rod and the body cross-member. Mine is from a '72 4x4 Blazer but I'm pretty sure it is the same on a K10. Link below to my WTB thread with pictures in the Blazer section.
http://67-72chevytrucks.com/vboard/s...d.php?t=716366
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Re: WTB: Parking Brake Cable Spring ('72 4x4)
Our local Ace Hardware has an extension spring selection and they carry a spring that is pretty close to what you need.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks Jim, I may end up having to go that route. Right now I don't have anything to go off of so I'd like to find one from a part out or even if in rough shape I can use it as a guide for a close hardware replacement.
Still looking
post labour day bump
Jeff,
I have one I could send you for shipping price. I will get a picture when I am back Sunday evening. John |
John. That would be great.
Thanks, Jeff.
Here you go. Not perfect but may work for you.
Came of 72 LWB
John. I really appreciate your effort on this but the one off my Blazer is only about 7" overall length so that one won't work.
Again thanks for trying.
We have several 4x4's and one Blazer and the springs are the same approximate length as the 7" length you mentioned. I will check with my local hardware to see if they have one that will work for you.
Jim
Around me I haven't had any luck. I found one close at 6.5 but the gauge of wire was much thicker and much higher pull force.
If you see something I'd be interested in knowing. Thanks. I did find one online but minimum order was 100 pieces!!
#15 |
I measured the one stock extension spring that is on one of my trucks and the approximate measurements are as follows:
Length 7" Diameter 1/2" Wire diameter .o67 Ends 1 1/2", (both) Wound coil length, 5" I have not been able to check out the springs at the hardware but will so soon as I found that I need one, also! Jim
#16 |
![]() Join Date: Apr 2012
Jeff,
If you can't come up with anything, I think I have one. Let me know, and I will look for if. Paul |
#17 |
Paul. Yes I'm still needing. Please take a look and let me know.
Thanks.
#18 |
No luck on springs at the hardware store.
Jim
#19 |
Thanks for looking. Maybe Paul will find the one he mentioned.
#20 | |
After looking around and pulling the same spring off of my 4 Blazers, I think I can say without a doubt this is the correct spring. Paul |
#21 |
Wow. Thats where they all are.
PM me what you want for one and Ill get you payment sent. In fact I'd go for two if you want to get rid of more. Thanks. Jeff.
#22 | |
Just PM me a shipping address and I will send you one, assuming you have a US address for shipping. Just put me in line if your Blazer ever needs a new home. Paul |
#23 |
Paul PM sent. Thank you very much.
