Old 10-03-2016, 10:10 AM   #1
Rick4076
doorr hinge removal
I have to slam my driver door to get it to close. It seems that it his hitting the inside door rubber before it's even close to closing and puts a major bind on the door. I replaced the door pins and bushings but that didn't help. I tried moving the door in and out at the hinges but it seems like that they are as far out as they can go so my next attempt will be to replace the hinges and possibly shim behind them. Do you have to remove the fender to get to the hinge bolts or is there another way?
Rick4076 is offline   Reply With Quote
Old 10-03-2016, 05:42 PM   #2
71c10tim
Re: doorr hinge removal
you have to remove the fender no real other way
71c10tim is offline   Reply With Quote
Old 10-03-2016, 06:55 PM   #3
kaycee
kaycee's Avatar
Take the door off, or sacrifice a 9/16 wrench and make it work heat and bend into a u -shape
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 10-03-2016, 09:28 PM   #4
Rick4076
I do have a bent wrench put I can't get my hand in the small space to shim the door so I think I'll have to agree with taking off the fender. Thanks for the suggestions.
