Old 10-03-2016, 11:50 AM   #26
Marshy
Re: First motor start, terrible knocking
Originally Posted by Lefkada View Post
I'm having trouble figuring out the head gasket thickness. I used the heads gaskets from this Fel-Pro KS2600 kit: https://www.summitracing.com/parts/fel-ks2600/overview/
Those have the fel-pro 7733PT-2 gasket and is .039-.040" compressed.
Let us know the cylinder head casting #'s when you get a chance.
Last week there was a guy asking if he could bolt on a pair of Vortec heads and replace a set of 882 heads. I told he he could but needed to consider the change in compression because the vortec heads were 64cc's vs the larger 74cc's of the 882 heads. I gave an example with flat top pistons with -4cc valve reliefs and a .040" quench clearance the compression was 9.5:1 with the larger heads but jumped to something like 10.5:1 (IIRC) by bolting on the smaller heads. The example I chose sounds like it could resemble your build but obviously just a guess because you don't know your deck height. It wouldn't be uncommon to zero deck a block and run flat top pistons and that head gasket like you have. Just something to be aware of.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 10-03-2016, 12:22 PM   #27
Lefkada
I just pulled off the valve cover.
Original head casting number: 3998991
New heads given to me by machine shop: 3986388
1972 C/20 LWB, 350/350
Lefkada is offline   Reply With Quote
Old 10-03-2016, 12:24 PM   #28
Lefkada
I will start going down that checklist, suprachrgd82. Thank you.
Old 10-03-2016, 12:39 PM   #29
haycatcher
I had a valve get stuck in the guide once after an engine rebuild and waiting a few months to fire engine. The valve bent and hung open creating dead cylinder condition. Had to pull head and replace valve and the guide to remedy. check compression to see if a cylinder is way off from others.
Was the water pump replaced? Someone advised check ancillary components or remove them from equation when restarting engine.
haycatcher is offline   Reply With Quote
Old 10-03-2016, 12:47 PM   #30
Marshy
Ok, they are the same CC so should not be an issue but worth the time to check.
If you are looking for a boroscope and don't want to spend a lot of money you can buy ones on ebay that connect to your phone. Check this out...
http://www.ebay.com/itm/3-5-5M-7mm-A...nq6Jx8qOrBmASw
Vortec Engine Build
Old 10-03-2016, 01:29 PM   #31
Gmc.guy
Gmc.guy's Avatar
Check your dipstick and fuel pump pushrod
-Cody
Gmc.guy is offline   Reply With Quote
Old 10-03-2016, 04:09 PM   #32
Lefkada
I have an electric fuel pump so I removed the fuel pump pushrod and installed a plate over the engine opening.
Old 10-03-2016, 04:10 PM   #33
Lefkada
Boy, I really hope that isn't my issue. I will check compression next if I don't find anything wrong with the valve adjustments.
I did not replace the water pump. Just cleaned it, painted it and put it back on.
Old 10-03-2016, 04:18 PM   #34
BILT4ME
Are all the bolts tight on the torque converter? It sounds to me like a rotational issue, not a linear "hammering" issue.
Also, do you have a stethoscope to check location of the noise? I know you don;t want to run it any more than you have to, but in order to find the problem.
I think a TC bolt is loose just a bit (or all of them) and they are hitting the lower lip of the back of the block. I think this because it has kind of a "ratchet" sound to it.
Good luck.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 10-03-2016, 04:53 PM   #35
geezer#99
geezer#99's Avatar
When you adjust the lifters again, remember to do the 'wiggle' the pushrods and not the 'twist' the pushrod method.
Old 10-03-2016, 06:22 PM   #36
Lefkada
Alright, I checked the flex plate and torque converter - both feel solid.
I loosened all rockers up by 1/2 turn and ran the motor. The sound was still there, so I crawled underneath and put my ear right up to the oil pan (I have no stethoscope) and could definitely hear something knocking inside. Looks like I'll be pulling the pan now.
I really appreciate everyone's guidance on this so far.
Old 10-03-2016, 06:41 PM   #37
BILT4ME
You can use a long screwdriver and press it to your ear and touch it to different areas on the block, valve cover, oil pan, etc.
Did you do anything with the oil pump while you had it out? Did it suck up some debris in the oil pan and the pump screen fell off?
It does NOT sound like the crankshaft is hitting anything and does not sound fast enough to be related to the cam (it turns half the speed of the cranks).
Distributor not seated
Starter dragging or rubbing the flywheel
Timing chain rubbing the cover
Oil pump shelling out
Accessory (AC Pump, Alternator, PS pump) dragging/rubbing/hitting/dry
Transmission pump dry (Is there fluid in the transmission?)
Parking Pawl dragging inside the transmission
Transmission in gear due to improper adjustment....
Too long of a bolt in the TC cover dragging on the teeth of the TC
Just spitballing to throw out ideas.......
1970 GMC K2500
Old 10-03-2016, 07:11 PM   #38
Lefkada
I didn't remove the oil pump but did remove, clean and reinstall the oil pump screen. I guess we will find out if something fell apart after I pull the pan tonight.
I have a little over 4 quarts of ATF in right now as I read you should not put all 10 quarts of ATF in, but start with around 4qt, shift through the gears, and then put the rest of the 6qt in. I hope this is correct.
Old 10-03-2016, 07:46 PM   #39
Boog
laying low
Boog's Avatar
I don't know about the differences between those two head castings but could it be the rockers are binding with the valve rotators? That's an angry sounding noise. It stands to reason the only changes made were the head exchange so this noise should be related to the heads.
How is the oil pressure?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-03-2016, 08:06 PM   #40
Lefkada
I looked up the head castings (http://outintheshop.com/faq/casting/heads.html) and there seems to be no difference in specs. One was used on 307's/350's and the other used on just 350's.
Oil pressure reads high on the stock gauge.
I just added 2 more quarts of ATF (I'm at 6-7qt now) and the sound remained, so I don't think it's the tranny pump.
Old 10-03-2016, 08:35 PM   #41
Boog
laying low
Boog's Avatar
Oil pressure is higher than before the head swap?
Have you run the engine with the valve covers removed to see that all the valves are moving up and down an equal amount and that oil is getting to the top of the rockers?
I don't believe that noise is tranny related.
Boog
primer is finer
Old 10-04-2016, 11:57 AM   #42
Lefkada
Sorry for the confusion. I meant that the stock gauge reads oil pressure as "High". I'm not sure what oil pressure was like before the rebuild.
All rockers seem to be getting good oil flow.
Old 10-04-2016, 12:22 PM   #43
Marshy
Did you turn the motor over without plugs in it yet? I'm wondering if maybe you should take the plugs out and turn it over by hand to see if you can feel where it might be "catching" and listen to the possible source of noise. That will eliminate all other background noise. Good luck.
If you dropped a valve it would be hammering away. The plug might give you some insight if its off color of has metal flake on it.
Vortec Engine Build
Old 10-05-2016, 04:49 PM   #44
Lefkada
Well now things have gotten bizarre. I'm working on removing the oil pan right now. I had 5 bolts out, and while removing the 6th bolt, untainted coolant begins leaking out of the bolt hole.
I have no idea if this is a secondary issue, related to a bad gasket or something, but this is strange. The oil doesn't look to have coolant mixed in, and the coolant doesn't seem to have any oil mixed in.
Old 10-05-2016, 04:56 PM   #45
Lefkada
I haven't cranked it without the plugs in yet, but I will give this a try.
Old 10-06-2016, 08:10 AM   #46
Jason Banks
Jason Banks's Avatar
How bent was the one pushrod? If the cam was messed up underneath that lifter and you put in a new pushrod. Whoever suggested running with the valve covers off could be on to something.
Jason Banks is offline   Reply With Quote
Old 10-06-2016, 08:43 AM   #47
Shinysideup
Shinysideup's Avatar
Sounds like a spun bearing from the beginning. Now you confirmed noise from bottom end and coolant in oil. Good thing top end already rebuilt, now freshen up the lower end and have a tight motor again.
Shinysideup is offline   Reply With Quote
Old 10-19-2016, 09:53 AM   #48
Marshy
Any update?
Vortec Engine Build
Old 10-19-2016, 11:19 AM   #49
mcbassin
Still Learning
mcbassin's Avatar
That video was hard to watch. Unfortunately, it sounds like some catastrophic damage to a piston or rod bearing or something. I'm hoping to hear good news but dang...
