Old 09-25-2016, 10:01 AM   #876
62 Barnfind
62 Barnfind's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Your truck is coming along great! Before long you will have it done and driving! Irefully like that you are doing it yourself.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 09-25-2016, 11:14 AM   #877
TJ's Chevy
TJ's Chevy's Avatar
Looking good dude!
Old 09-25-2016, 01:39 PM   #878
with the above
Old 09-25-2016, 03:39 PM   #879
mehoff400
Looking great!!! wish my project was moving like yours is... mine will be on hold for a little as i got a wedding to pay for now.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 09-26-2016, 12:16 AM   #880
62stepside longbox
62stepside longbox's Avatar
Thanks John, hopefully it will drive for the first time this spring. Doing it yourself is what hotroding is all about , plus I'm cheap
Originally Posted by TJ's Chevy View Post
Looking good dude!
Thanks tj, glad to see you getting back to two tone now that crustine is back on the road.
with the above
Thanks bill
Thanks man, I'm really trying to make progress but it can be hard with school and work, and of course I know what it's like to be on a tight budget. Keep on plugging away at it and you'll be done eventually
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 09-26-2016, 07:29 PM   #881
62stepside longbox
last night I made a template for the booster and clutch master and brought it in to shop class today to make it. I used 10 guage cut on the plasma cutter and cleaned it up with the grinder. This is uses the exact same dimensions as captainfab's bracket except it doesn't push it outwards as I need as much room as possible to clear the oilbath aircleaner. I still will need to drill the holes in the firewall for the booster but the hole point in this bracket is to reinforce the area where the clutch master goes since it is only 18 gauge and a lot of pressure will be on it while pushing in the clutch
Old 09-26-2016, 07:31 PM   #882
62stepside longbox
Here is both the brake booster and clutch master mocked up on the bracket
Old 09-26-2016, 07:31 PM   #883
62stepside longbox
Another
Old 09-26-2016, 09:17 PM   #884
TJ's Chevy
TJ's Chevy's Avatar
Nice!
Old 09-27-2016, 09:56 AM   #885
65sub
65sub's Avatar
HI Nik I just got caught up on your progress.Looking good. Keep up the good work
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 09-27-2016, 10:34 AM   #886
66ChevyMax
66ChevyMax's Avatar
Very nice!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 09-27-2016, 11:03 AM   #887
Deer_hunter_088
Deer_hunter_088's Avatar
Originally Posted by 62stepside longbox View Post
Good to see another guy my age thats into this stuff instead of playing video games all day like my other friends
im a 16 y/0 also restoring a truck,
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-27-2016, 12:23 PM   #888
62stepside longbox
Nice!
Thanks tj
Thanks Dale, good to hear from you, it's been a while.
Originally Posted by 66ChevyMax View Post
Very nice!
Thanks Craig
Greetings, always good to see more young guys
Old 09-29-2016, 09:11 PM   #889
62stepside longbox
So today after school I got the four holes drilled in the firewall for the booster, they were not a piece of cake but not terrible either. The top two holes had multiple layers to go through which was pretty easy but the bottom two holes were a bit more trouble, once I got through the first later the drill bit hit the second layer which was on an angle and the bit kept on wanting to jam up but with some patience I was able to get through just fine. Here is the bracket mocked up on the firewall.
Old 09-29-2016, 09:21 PM   #890
62stepside longbox
I also have some more news, this project just keeps on snowballing. First it was "if I'm going to switch the x member then I might as well take the engine out" then "if the engines out I might as well clean it up and paint it" and then "while I'm at it I might as well do power steering, power brakes" and so on. Well I've done it again, I decided that while the engine is out I might as well paint the firewall since I don't want to take it this far apart in the future. So I have just put in an order for 503 glenwood green with one of my friends that is a painter so he can get very good paint for very cheap. I'm hoping to have the firewall in paint and the engine back in before it gets too cold
Old 09-29-2016, 09:48 PM   #891
72cs20
Exactly! But it'll be worth it.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 09-30-2016, 07:39 AM   #892
Oh yeah, that list.....since I am this far why don't I also do......
Old 09-30-2016, 01:44 PM   #893
TJ's Chevy
TJ's Chevy's Avatar
Heck man, that's what my 66 was supposed to be...and look what happened.
Old 09-30-2016, 07:02 PM   #894
62stepside longbox
Oh yeah it should be
Yep! That's how all these projects work, went from doing a couple things to now doing a full restoration! Funny how that works
Yep lol, yours has gone from a daily driver build to a frame off restoration. seems like all projects go that way
Old 10-03-2016, 09:39 PM   #895
62stepside longbox
Got the booster and bracket fitted up against the firewall, I had to open up the hole for the pushrod a bit so the rubber boot would fit. Now all that needs to be done is to drill the holes for the clutch master cylinder.
Old 10-03-2016, 09:41 PM   #896
62stepside longbox
02
Old 10-03-2016, 09:42 PM   #897
62stepside longbox
03
Old 10-03-2016, 10:11 PM   #898
AJCK87
Looks good Nik! Nice progress
AJCK87 is offline   Reply With Quote
Old 10-04-2016, 10:54 AM   #899
62stepside longbox
Thanks Anthony
Old 10-04-2016, 12:55 PM   #900
RKS0069
RKS0069's Avatar
Very nice! You are doing an amazing job.
I bought my first truck ('72 c10 swb) when I was 16 years old. drove it for a few years and then started striping it down but with minimal tools and money I did not get past that point, so now I'm 38 and still have the truck in pieces.
I bought a '62 GMC roughly twelve years ago and drove it most of that time, now I have it ripped down as well, yes two trucks in pieces. Every time I see your posts I kick myself in the butt for not working on my truck more. I'm not letting that happen to the GMC! Thanks for all the motivation, looking forward to seeing you complete your truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline   Reply With Quote
