In need of help 70 c-10 cranks but wont start
In need of some help. I was driving my 70 c10 and it cut off. Now it just cranks but wont start. I have fuel before and after inline fuel filter and tried starter fluid and still nothing
Re: In need of help 70 c-10 cranks but wont start
No spark??
What ignition? Points or hei? |
Fuel Air Ignition takes all three.
Since we know zip about your truck I'd guess you have an ignition problem. Do you have a service manual preferably a 70 factory chassis service manual?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Spark is present and i do not have a manual. Previous owner added and electronic ignition i believe
Spark is present and i believe it was upgraded to an electric ignition
What motor?
What carb? |
Straight 6 4.1 and its a single barrel carb not sure of the brand or anything
Check the distributor isn't loose and easy to rotate.
