Highest ratio gears usable??
I would like to change my ring and pinion to higher (lower numerically) ratio. I have a 350-300 hp with auto. Truck is almost never used for hauling and winds a lot on highway. I think it has 4:11s now.
Anybody change theirs with success? |
![]() Join Date: Jul 2015
Re: Highest ratio gears usable??
3:08s is what most these trucks came with stock. A lot of guys like 3:73's, give a little more umph off the line but doesn't send your rev's through the roof. I have 3:73's in my truck and love em.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
I have 3.73's in my 4x4, but if I were driving a lot of highway miles over 55mph, I'd probably look into a set of 3.42's.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
![]() Join Date: Mar 2012
is a 3:55 available for the 12 bolt? it is a good ratio
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
4.56's with a Gear Vendors over/underdrive, perfect lol
You don't mention your tire size. That's a critical component in determining what your final drive ratio will be.
Its a Truck Thing......
I put 3.42's in mine and with OD it works well on the interstate. If you have 4.11's now, you will have to change your carrier to a 3 series carrier. Someone else can chime in on that one...
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#9 | |
Thanks Posted via Mobile Device |
#10 | |
![]() Join Date: Feb 2016
http://www.4wheelparts.com/off-road/...-diameter.aspx
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Because as the pinion gear gets smaller the ring gear mounting on the differential case has to move over.
Tire size is important, agreed. What do you have OP?
Think I've got a 235/70/15 along with 3.08's. Allows me to cruise at 70mph no problem.
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
as the gear ratio goes up or down the size of the gears go up or down so the carrier needs to get sized to fit the ring gear series 4 carrier does 373 to 411 or higher and series 3 carrier goes from 308 to 342 . I can never remember witch but one set wont fit the carrier at all and the other set will slide down the carrier but the bolt holes will be way off
#15 | |
