![]() Join Date: Sep 2012
Washer Fluid Pump Mounting Location
Well I'm quickly learning that when you start a build, either do it a lot quicker than I have been or take LOTS of pictures before disassembly. I did take what I thought at the time was a lot of pics of everything but a few things slipped by.
Does anyone have a picture or direction where the washer fluid pump mounts? I know it may be difficult to get a good picture. Thanks in advance. |
Re: Washer Fluid Pump Mounting Location
it is located up in back of the dash it is mounted on top of the windshield wper pump
20' Daredevil (Ret)
![]() Join Date: May 2003
It's buried up under the dash, behind the gauge panel IIRC. Someone should jump in with a pic or illustration.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
I do remember it is mounted up under the dash, just can't seem to find the holes it mounts to.
![]() Join Date: Jan 2001
It's located on the wiper motor.
Old member
It mounts to the wiper electric motor. It's not mounted to the fire wall itself.
This is off another subject. Not my picture either. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Sep 2014
Here you go,
From our own web site, try this link (a few years ago) http://67-72chevytrucks.com/vboard/s....php?p=4365093 This is what makes this site so beneficial. Hope this helps. Good luck |
