Closed Thread
Old 10-06-2016, 10:40 PM   #4451
tommy3horse
tommy3horse's Avatar
Re: What did you do to your truck today? Chapter II
Put her to work, hauled 3 loads of firewood about 20 miles thru the back roads...nice day today.
Tom
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 10-06-2016, 10:44 PM   #4452
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Always nice to see one working as they are meant to be !
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-07-2016, 01:44 AM   #4453
Gillnetter
Gillnetter's Avatar
Got my new crate motor installed tonight.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline
Old 10-07-2016, 02:48 AM   #4454
66clow
66clow's Avatar
Originally Posted by Custom/20 View Post
Got rid of the 20 year old exhaust system and swapped out the ram horns with some summit brand headers and some flow master 40s that dump right before the rear end.
Where you get your spark plug wire holders? Nice and clean
66clow is offline
Old 10-07-2016, 10:15 AM   #4455
88Stanger
88Stanger's Avatar
Just got the entire truck built from scratch and running, got 100 miles on it and after some good financial things, changing out iron heads to aluminum, new intake to match, change to floor shifted auto, new dual electric radiator fans, full MSD ignition and finally taking out 3.07 non-posi gears and installing all new Eaton Posi, 3.42 gears. this will finish off 90% of the real wants for the truck. It truly is a never ending story....
88Stanger is offline
Old 10-07-2016, 07:21 PM   #4456
RodnRudy
RodnRudy's Avatar
I took my freshly powder coated rallys to Discount Tire and had them install new rubber. I went with 225/70 15 on the front and 275/60 15 on the rear. Went with Cooper Cobras, they were almost $300 cheaper than Goodrich TA's. I'm kind of liking the look without trim rings but I'm going to get them eventually.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 10-07-2016, 08:30 PM   #4457
66clow
66clow's Avatar
Looks great!
66clow is offline
Old 10-07-2016, 08:57 PM   #4458
OregonNed
OregonNed's Avatar
I'm curious too.... looks great! Any issues with the one side clearing the oil dipstick?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 10-07-2016, 09:40 PM   #4459
In The Ten Ring
Loaded up the oil and antifreeze I drained in 2013. County is doing a free old fluid collection tomorrow. I couldn't get rid of that antifreeze anywhere! No one would take it.
The old gasoline was easy to get rid of, just did a "free for hauling" ad and it was gone the day of printing.
In The Ten Ring is offline
Old 10-08-2016, 09:21 AM   #4460
Econman
Econman's Avatar
Chip guard applied to the bottom of the cab. Now to prime it and spray some color.
Econman is offline
Old 10-08-2016, 01:48 PM   #4461
berch 69GMC
berch 69GMC's Avatar
While removing hurricane shutters, the mailman brought me some interior pieces created by Grumpy Old Man. They are gorgeous!
[ATTACH]Name:  WP_20161008_13_29_00_Pro.jpg
Size:  57.4 KB[/ATTACH]
berch 69GMC is offline
Old 10-08-2016, 02:35 PM   #4462
Econman
Econman's Avatar
Attachment 1578822
Attachment 1578823
Color!!
Econman is offline
Old 10-08-2016, 07:21 PM   #4463
OregonNed
OregonNed's Avatar
I purchased a new, stock oil dipstick and installed. A perfect fit. Also replace the new Earls swivel fuel pump to line connector I bought new that leaked - Summit shipped me a new one immediately, (kudos to them!) and the new one is perfect - no leaks. Took the truck for an early fall drive too.
Old 10-08-2016, 07:43 PM   #4464
GR8-68
GR8-68's Avatar
Put on the second coat of frame paint ( POR )
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 10-08-2016, 08:00 PM   #4465
testerdahl
Reassembled exhaust manifold, put on new carburetor and modified oil bath to fit. Painted and cleaned quite a bit of the engine as well over the past 2 days.
Took a video: https://youtu.be/Y-A3Yy8nXAs
testerdahl is offline
Old 10-08-2016, 10:04 PM   #4466
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Drained tank, removed some fuel lines. Removed hardware from the bench seat, stored bench seat with spare boxes under the cap on my Tundra. I don't have the luxury of a lot of space, but a tear-down sure uses it up. I have parts in four rooms and the garage of course. The wife loves it.
Trust me, the build will be FAR easier than the tear-down.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 10-08-2016, 10:44 PM   #4467
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
I drove the ramp truck loaded with my gas cart to our local truck club picnic!
I was happy it made the 3hr ride with no problems other than the radiator is leaking.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 10-08-2016, 11:03 PM   #4468
mud.man.rj
mud.man.rj's Avatar
Good looking ramp truck, don't see those very often and useful too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-09-2016, 12:29 AM   #4469
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Hey, Mud.
Yeah. Nice.
I could have used that truck more times than one.
Today, I finally uncovered RAT and put the charger on the battery. Tomorrow, if it doesn't start,
I've got family here to hand-put her in the garage.
I've waited too long to change out the starter. Pressed my luck.
Now, it's time to climb under. Also, I'm putting in a little better quality electric fuel pump...replacing the
cheapo that's on the frame rail behind the passenger side of the cab.. I forget what the new one is. But it's healthy.
The old one seemed to starve out the carb when I was either taking a long "passing" upgrade...
....Or when I was being a "Bad Boy".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-09-2016, 12:34 AM   #4470
mud.man.rj
mud.man.rj's Avatar
About time you got back to the old girl Mag, miss you posting that beauty.
5.0 4spd std.
7" lift w 35's.
Old 10-09-2016, 04:28 AM   #4471
66clow
66clow's Avatar
Bought some reclaimed wood and cut to fit. Now need to bolt it down. $150 worth of wood. Bought a bunch of new bolts at loews for $25. May sand and stain later down the road. Hasn't had a bed floor since I bought it in March. Should quiet down the turndowns some or echo louder.
66clow is offline
Old 10-09-2016, 05:42 AM   #4472
ohboy321
ohboy321's Avatar
Fixed a broken wire on my alternator. Not sure when it broke but it left me stranded at the supermarket on Saturday. AAA had it back in the driveway in no time and it was an easy fix. AAA guy said it was his 5th antique of the morning...there are a lot of leaf peepers this time of year. One of the PO's was not so handy in the wiring department.
I picked up the truck in June, and have put 1000+ trouble free miles on it. I have no complaints whatsoever considering where I started.
ohboy321 is offline
Old 10-09-2016, 09:18 AM   #4473
VWNate1
VWNate1's Avatar
Post Routine Service
Nice ! .
I like your rig and the 235, especially the painted " CHEVROLET " on the rockerbox .
Those are very easy to tune sharply for good power and smooth as silk idle, just ask .
-Nate
VWNate1 is offline
Old 10-09-2016, 05:23 PM   #4474
jescates
jescates's Avatar
Installed billet radio bezel that's been sitting in my garage for 8 years! Now to get some speakers and a new radio!
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline
Old 10-09-2016, 05:41 PM   #4475
ghalperin
ghalperin's Avatar
I repaired the broken door check strap on the driver's door. It took me less than 30 minutes with parts from Classic Parts. I used a 3/16 roll pin punch to remove the roll pin. I had to remove the door panel to gain access.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Closed Thread
