Old 07-31-2016, 10:19 AM   #51
Dustmaker65
Dustmaker65's Avatar
Re: Cutting 3 cabs up...
Originally Posted by gmc 2500 4x4 View Post
i didnt get a pm
Here is pic of tag...
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 07-31-2016, 04:13 PM   #52
Dustmaker65
Last call on cab cuts... Will be outside finishing up with them. Shoot me a text at 309-231-4082 if ya need something!
Thanks to all of the guys that have bought pieces!
Jimmy
Jimmy Hoelzel
Old 07-31-2016, 04:28 PM   #53
gmc 2500 4x4
thanx Dustmaker65 i found my plate, mine has many coats of paint and i hope i can strip it off . i;ll pass. hang on to it!
gmc 2500 4x4 is offline   Reply With Quote
Old 07-31-2016, 10:07 PM   #54
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Any chance of getting a cut of the lower rear window channel?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 08-01-2016, 07:44 AM   #55
Dustmaker65
You want the whole length? Inside and outside?
Thanks!
Jimmy
Jimmy Hoelzel
Old 08-01-2016, 09:07 AM   #56
derotoreut
derotoreut's Avatar
Thanks!
Jimmy
I need whole back length from one side to other. I don't really need inside but if its easier to cut that way then thats fine. I need about 3-4" under window and then maybe half way up (at most) on the sides. Enough to replace rusted area from picture.
Let me know how much and shipping to 14036. Thanks.
~ Dan
Old 08-02-2016, 06:13 PM   #57
Dustmaker65
Here is a pic of one that is solid. It does have a little surface rust, but metal is solid. No problem cutting this off for you, but shipping may be expensive?
Let me know.
Jimmy
Jimmy Hoelzel
Old 08-02-2016, 07:48 PM   #58
Woodnears
I might be interested in the door pillars. Would need both sides. A few of my door hinge plates that hide in mine are stripped out. All depends what shipping would be
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 08-02-2016, 10:04 PM   #59
Dustmaker65
Let see what I have. I will get a picture for you tomorrow.
Thanks,
Jimmy
Jimmy Hoelzel
Old 08-03-2016, 05:59 AM   #60
PDXk5
PDXk5's Avatar
If you have them and it's not too late... I'm looking for solid toe kick panels. Both passenger and driver side. Mine have a bit of rust through on the panel right where it meets the floor.
Thanks!
PDXk5 is offline   Reply With Quote
Old 08-03-2016, 07:22 AM   #61
derotoreut
derotoreut's Avatar
Let me know.
Jimmy
Are any areas rusted through? Bottom right looks like it might have holes through it. I would need an idea of price with shipping before I can say. Otherwise if its too expensive I'll have to pass.
~ Dan
Old 08-04-2016, 05:35 PM   #62
6T7NCHVYC10
6T7NCHVYC10's Avatar
Got it today. Thanks Jimmy
6T7NCHVYC10 is offline   Reply With Quote
Old 08-04-2016, 10:41 PM   #63
toomany2yz
I'm looking for the drivers side A-pillar, mainly where the lower hinge bolts to...if it isn't too late. Can get pics of what I need.
toomany2yz is offline   Reply With Quote
Old 08-05-2016, 01:01 AM   #64
Dustmaker65
I have been working 12 hour shifts, and no time to get out to look over the cabs yet. I will this weekend for sure. Post a pic of what area you are looking for.
Thanks!
Sorry, but the kick panels that are left are not worth cutting out.
There are no areas rusted thru. Actually very solid. As for shipping, I am not to good at "guessing" or calculating it. I am sure if you want it in one piece, it will be expensive. But I could cut it down in sections to ship?
Thank You!
I can look at the cabs this weekend. Post a pic of area you are looking for and I will see what I have.
Jimmy Hoelzel
Old 08-05-2016, 09:54 PM   #65
toomany2yz
Here is a picture of the area I need. If I could get from midway between the hinges to where the fender bolts to...that would be great.
Old 08-06-2016, 07:59 PM   #66
Dustmaker65
Door pillars are all shot. Sorry.
Thanks!
The rest of the kick panels are rotted. Sorry.
Door pillars are all rotted. Sorry.
Jimmy Hoelzel
Old 08-06-2016, 08:01 PM   #67
toomany2yz
Ok, thanks for looking.
Old 08-10-2016, 10:57 PM   #68
Caudillo64
Caudillo64's Avatar
I'm looking for driver side door retainer arm that comes out of the cab to keep door from opening up all the way. mine broke off my 1965 C10
Caudillo64 is offline   Reply With Quote
Old 08-11-2016, 09:32 AM   #69
Dustmaker65
Are you looking for the top hinge? I am not sure what you are wanting. You have a pic?
Jimmy Hoelzel
Old 08-12-2016, 08:47 AM   #70
Caudillo64
Caudillo64's Avatar
I'm looking for the piece that comes out of the cab.
Old 08-12-2016, 09:41 AM   #71
Dustmaker65
Sorry, mine are totally different than yours.
Jimmy Hoelzel
Old 08-12-2016, 05:04 PM   #72
MidLifer
MidLifer's Avatar
Dustmaker, I know you said earlier in the thread that the floors are pretty gone, but just checking on this - I would like a low hump with enough "meat" around it so that I can bolt it into where a high hump was. I have one that I purchased from a board member but when I went to test fit it last night, I would need to weld sheet metal onto it to make it fit.
Do any of the cabs you have left have good sheet metal in this area that could be cut out? I could send you some pics and dimensions if needed.
MidLifer is offline   Reply With Quote
Old 10-07-2016, 08:12 PM   #73
Undone
I need both rh and lh back window frame corners 2 inches wide, 6 inches up and 6 inches in, inner and outer.
Undone is offline   Reply With Quote
Old 10-07-2016, 08:45 PM   #74
Dustmaker65
Sorry...all the cabs are gone.
Jimmy Hoelzel
