Old 10-03-2016, 11:45 AM   #1
Mrturner1
Finally did some wrenchin w/ the hood CLOSED
Well I've been in this fight with my engine which is my first one, I did a heads/cam/intake/carb swap on an old used short block that just refuses to die. I put some halfway decent heads on, a cam that's WAY WAY to big and choppy (like 10 second car choppy lol 106 LSA) and a big ole Holley 750 DP to top it off. It's been a struggle to get it driveable but I think I'm there finally, time will tell.
Anyway I have had this awesome Moser rear diff cover with bearing supports that's been collecting dust on the shelf because my engine needed all my attention (or maybe it didn't and that's they key) so this morning I decided to open the diff up and clean, check, and install the new cover. It's a 12 bolt with a mini spool and 3.73's, which should last me and be sufficient for anything I decide to do with the truck. It's going to the track someday but it needs suspension and brakes first
Anyway, easy install, took 45 minutes just putting along and it looks really nice. Not a bad 150 bucks IMO
Mrturner1 is offline   Reply With Quote
Old 10-03-2016, 11:46 AM   #2
Mrturner1
Re: Finally did some wrenchin w/ the hood CLOSED
Here's the finished product. I'm taking the helper springs off later today
Old 10-03-2016, 12:19 PM   #3
davepl
davepl's Avatar
Whew! I can smell that fluid from here!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-03-2016, 01:08 PM   #4
Mrturner1
No kiddin it's pretty foul. I read that a 12 bolt needs 2 liters of gear oil so I put in 1 for now until somebody can chime in on an exact amount.
Old 10-03-2016, 01:33 PM   #5
cleszkie
cleszkie's Avatar
You add gear oil until it starts to leak out the filler hole. That is how you do it. Don't starve your pinion bearings by under-filling it.
BTW - you drive on the street with a spool? That's hard on the tires, and generally hard on the axles during turns, as I'm sure you've heard your tires complaining (chirping). Spools are great for off-road use or straight line racing, but not so much for dd use.
cleszkie is offline   Reply With Quote
Old 10-03-2016, 01:44 PM   #6
Mrturner1
Fill to fill plug overflow even on aftermarket diff cover?
lol it's far from a daily driver, I'm lucky if a get a short drive to the market in town once a week. But it sure is a fun ride it'll see track time once I get the safety stuff all done and I can stop this flying brick. It does chirp on U-turns and in parking lots, it's kindof entertaining. Anybody who knows why it's chirping and is walking by gives a smile and thumbs up.
Old 10-03-2016, 03:14 PM   #7
cleszkie
cleszkie's Avatar
Yes. I can't imagine that the Moser cover has the fill hole much higher than the stock cover. But if it does, in order to avoid the built-in bearing supports, I would still fill it to this level because the bearing supports are taking away from the internal oil volume, and raising the oil level in the diff a little will make up for that. The more oil you have, the cooler the diff will run. You just don't want to fill the diff to the gills, or else you run the risk of forcing heated oil out the breather tube.
Old 10-03-2016, 03:22 PM   #8
Mrturner1
Actually the factory diff cover didn't have a drain or fill plug at all, probably half of the reason I got the new cover to be honest
Old 10-03-2016, 07:38 PM   #9
TrkEnvy
X2. I was wondering how much to add cuz I can't use a girdle. I think my ece bar would hit it.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 10-03-2016, 09:47 PM   #10
Mike C
Mike C's Avatar
Why not use the OEM fill plug in the side of the diff case? That's what it's there for...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-03-2016, 10:12 PM   #11
Mrturner1
Mines welded on over time by rust and gunk that got hard, I'd need a air hammer to get it off lol I think 2 liters does it from what I'm reading on Google
Old 10-04-2016, 12:56 AM   #12
Grumpy old man
Grumpy old man's Avatar
The hood may be closed but I see your still chasing shiny parts ? Ol bikers saying "Chrome won't get you home !" Buy a short bed frame !
Old 10-08-2016, 08:24 PM   #13
Mrturner1
Maybe I could mosey on over your way with a trailer and leave after a few Heinekens with a 67 short bed rolling chassis?? And maybe some goodies with it?
