Air Ride Questions
Ok this is for all the air ride guys have any of you installed a kit from airbagit, I have been working on this system for about two months on and off and to no avail it still leaks down, i have changed the fittings from the push lock to compression teflon taped everything, i bought the manifold and the swivel fittings on it leaked so i replaced them just wondering if anyone else has had these kind of problems, this is something i can't keep messing with, i'm about to pull it all off and just go static drop with the mustang ifs system.
![]() Join Date: Feb 2004
Re: Air Ride Questions
Airbagit is not known to have good stuff. With that said get rid of the Teflon tape and use loctite 545. That may fix your issues
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Thanks!! i found the culprit the one set of fittings i forgot about, the ones on the gauges they were leaking, lol they were about to make me spend another couple grand on all new suspension.
